M105 by hand vs 2500 grit wetsanding marks - Page 6
Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 70
Thread: M105 by hand vs 2500 grit wetsanding marks
  1. #51
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,314
    49
    Re: M105 by hand vs 2500 grit wetsanding marks
    Quote Originally Posted by kty10 View Post
    How much M105 would you recommend using, a few drops? I'm gonna work on a friend's very neglected daily driver this weekend and was considering using either M151 or M105, depending on how the test spots come out.
    Thanks for your help. I really appreciate it.
    The first time it will take a bit more to get the pad primed. After that I would try maybe 2-3 pea sized drops. Maybe someone else can chime in with more experience. I've only tried it 2-3 times with a DA. If you try it, post back and let us know what you did and how it worked for you.
    Good luck!
    Scott
  2. #52
    Registered Member Pocket_Aces's Avatar
    Sep 2008
    Fort Worth Texas
    42
    12
    So if I understand correctly, any hazing that may occur with M105 and a DA can be corrected later with using the DA and a finishing product right? The reason why I am leaning towards the DA is I am trying to fix a rock chip and don't want to use a rotary that might pull the touch up out. I would rather use the DA over hand since it will probably make a more uniform finish.
  3. #53
    Aug 2006
    Green Bay, WI
    3,314
    49
    If your doing a rock chip give it a try by hand. My first post in this thread was by hand with only one pass. M105 works amazing by hand.
    Correct if you end up with hazing you will need to follow up with a finer polish.
    Scott
  4. #54
    Jul 2006
    Orange County, CA
    36
    4,138
    145
    Quote Originally Posted by BlueZero View Post
    I agree. Go at that by hand and M105 first.
  5. #55
    Sep 2008
    Fort Worth Texas
    42
    12
    Thanks guys. I will give it a go by hand with the M105 then and maybe follow up with the DA and some light polish. I should be able to apply this stuff with an foam applicator from Autozone right?
  6. #56
    59
    24,767
    519
    Quote Originally Posted by Pocket_Aces View Post
    Yes or microfiber applicator pads.
    You can use terry cloth for a more abrasive bite but when you rub hard with terry cloth this can put toweling marks into the paint, thus the recommendation for foam or microfiber.
    Also, to understand why myself and these others have recommended hand over the DA for removing sanding marks, do an advanced search using the word,
    exert
    and read some of my comments on this topic in the threads your search brings up.
  7. #57
    Asst. Recon. Mngr AJ C-Burg's Avatar
    Jul 2008
    Chambersburg Pa
    24
    Great test, that looks awesome! That is a nice finish, you didn't polish or wax? I've been using 95 for awhile, but haven't tried 105 yet. Can't wait to try some!
    Knowledge is power
    2001 Silver Acura 3.2 CL
    1996 Red Jeep Grand Cherokee Laredo
    1978 21' Dodge RV (restored)
  8. #58
    Oct 2008
    Australia
    28
    12
    Hey was wondering if M85 could do the same thing? I don't think we stock M105 in Australia.
  9. #59
    Registered Member Lexus Guy04's Avatar
    Oct 2008
    Nashville Tennessee
    34
    471
    16
    Quote Originally Posted by RtN View Post
    I doubt it. M85 is a great product, but nothing compares to M105. It's in a class by itself if you ask me.
    '05 Arctic Blue Pearl Acura TSX
    '03 Silver Lexus RX 300
  10. #60
    Aug 2006
    Green Bay, WI
    3,314
    49
    Quote Originally Posted by AJ C-Burg View Post
    Sorry for the delay. I didn't use any other products for the photo. That's just with M105.
    I've never used M85 but if I had to guess I wouldn't think it would work. M105 is designed for use by hand or rotary, where as M85 is designed to be rotary only.
    Scott
  1. Will M80 remove 2000 Grit wet sand area? Or should I hand apply M105?
    By dhahlen in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Jan 3rd, 2009, 11:23 AM
  2. 21-09B vs 2500 grit sanding marks by hand
    By BlueZero in forum Consumer Line - Product Reviews
    Last Post: Oct 21st, 2008, 08:09 AM
  3. Can You Use the PC to Polish-out #2000 Grit Sanding Marks?
    By JJ1 in forum Hot Topics & Frequently Asked Questions
    Last Post: Apr 15th, 2007, 10:02 PM
  4. 2000 Grit Sanding Marks
    By imp2000ls in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Mar 9th, 2005, 01:57 PM
  5. wetsanding marks
    By Heynen in forum Detailing 101
    Last Post: Sep 25th, 2004, 04:44 AM
