Re: HELP #45 is blurring the surface after #49
I am in Folsom, California bought the #49 from West Marine. Funny thing is I was very surprised how nice the #49 left the surface. It was much better than I expected for a compound. I have completed the testing I mentioned and here are the results with pictures.
Each product was applied with it's own Megs High Tech Applicator wiped and then a second application was done followed by a wipe. Each area had it's own MF towel for wiping. No Wax was done during the test. The entire test area was hit with #49 wiped and then a second application and wiped before tape was applied.
Test Setup
Here is the area in which I applied #44 then #45. This one yielded the worst results.
Here is the application of #7
Here is the application of #81
Here is the application of #45
Under the vertical strips of tape is only #49 I too some comparisons pics.
#49 only left #49, #44, #45 right
#49, #7 left #49 only right
#49, #81 left #49 only right
#49, #45 left #49 only right
To me it looks like the #45 over #49 gave the least amount of haze but it not as clear as the #49 by itself. So I pose the question to the experts here why? What is it about #49 first that make the polish perform so poorly. I need help on this one as right now I am considering doing #49 then going over with several thin coats of #63. I know there is something amiss I just cannot determine as I am following the same procedures as I do on other portions of the boat. The only difference in this area was that I used #49 to remove some light oxidation.
I have owned the boat since new and the areas that have not experienced any #49 respond extremely well to #45.
The boat is stored directly next to my home in a secured area and thus is not subjected to anything unknown other than dust falling from the sky. The area tested was washed (#65 and Megs Marine Wash mitt) and dried (Marine Water magnets) prior to beginning the test.
Is there any problems in #49 and going directly to #63? I would like to complete the surface care and get back to using the boat. Any and all help is appreciated.... as I need it. Thank you!!
Test Setup
