Can't see rep when in user CP.
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Can't see rep when in user CP.
    They call me fitty 3Fitty's Avatar
    Mar 2008
    Toronto, Canada
    1,458
    31
    Just like the title says... when I go to my user CP I can't see my rep. Do I have to enable it somewhere?
    Formerly 101impala Andy M.'s Avatar
    May 2004
    Philadelphia, PA
    53
    3,969
    348
    Re: Can't see rep when in user CP.
    The only thing I can see on my user cp is when someone gives me rep. Which has only been once. Other than that I think it goes by post count and time on the site.
    Andy
    101impala
    Andy M. Moderator
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,314
    50
    I'm not sure how that works. When I click 'User CP' I see a section called 'Latest Reputation Received' but mine shows 5 items but only 3 have green dots in front of them.
    That and when did my rep power go to 23? Wow, I thought it was just like 4. Hmmm, Well I'm happy I'm being helpful.
    Scott
    Mar 2008
    Toronto, Canada
    1,458
    31
    Mine doesn't show anything with regards to rep and I have 6, which is about 8 rep points too many.
    Aug 2006
    Green Bay, WI
    3,314
    50
    Quote Originally Posted by 3Fitty View Post
    Heck, you should at least be up to 3 by now.
    This sort of kind of maybe explains it a bit better...
    Quote Originally Posted by vBulletin 3 Manual
    User Reputation
    This section contains many settings that dictate how users of your forum are able to affect each other's reputation score.
    * Enable User Reputation system
    This is the global switch for the reputation system. If you disable this, users will not be able to rate each other nor will their scores be visible.
    * Default Reputation
    This is the reputation score that new users will start out with.
    * Number of Reputation Levels to Display
    When a user enters their User CP, they will see a list of their most recent reputation ratings. This affects how many of the latest ratings to display.
    * Administrator's Reputation Power
    If you wish to have administrator's wield a certain reputation power independent of their calculated score, enter it here. Otherwise, set this to 0 and they will use the same calculations as everyone else.
    * Register Date Factor
    The number of reputation points that a user is able to give or take is dependant on several factors, with the length they have been registered as one of them. A user's power is first initialized at 1 and then this factor and the factors that follow are used to increase it. For example if you set this to 365, every 365 days that the user has been a member of your forum, they would gain one point. So if they have been a member for five years, they would gain 5 points of power for a total of 6.
    * Post Count Factor
    The amount of posts that a user has can also affect their reputation power. Set this to number of posts that you want to award one point for. For example, set this to 50 and for a user with 500 posts, they would gain 10 points of power.
    * Reputation Point Factor
    The users current reputation score can also affect their reputation power. Set this to 100 and a user with a reputation of 1000 would gain 10 points of reputation power. If you set any of the power factors to 0, that will effectively remove that factor from having an effect on the user's reputation power.
    * Minimum Post Count
    If the reputation system is enabled, anyone will be able to rate a post but only users with a post count above the level you set here will be able to actually give points or take points from another user.
    * Minimum Reputation Count
    As with the post count above, a user must have a reputation above this level to be able to give or take points from another user's score.
    * Daily Reputation Clicks Limit
    This sets how many unique members that a forum user will be able to rate in any 24 hour period. Administrators can rate as many people as they wish.
    * Reputation User Spread
    This setting dictates how many unique members that a user must rate before they are able to rate the same member twice. The goal of this setting is to stop a member from either artificially bumping or dropping a user by repeatedly rating their posts.
    Scott
    May 2004
    Philadelphia, PA
    53
    3,969
    348
    Quote Originally Posted by BlueZero View Post
    Hey Scott!
    Yeah mine jumped up today also. I think they all changed.
    Andy
    Andy M. Moderator
    Registered Member Mr Mustang's Avatar
    Apr 2008
    Florence, SC
    600
    19
    i never knew what rep points were, still a little fuzzy, but
    has mine changed...?
    yup, went from 1 to 4
    2004 Mustang GT - Sonic Blue
    Registered Member yalerd's Avatar
    Jan 2006
    4,439
    121
    I had 5 and now I have 27!
    Something has changed
    40
    19,215
    238
    66 does look a little high for me....
    Registered Nappers Nappers's Avatar
    Aug 2006
    Yreka, CA
    51
    3,551
    188
    It's all of those wonderful threads that you give the new guys Murr, cut and paste. Tried it but spent more time looking for my old threads with an older computer is was faster for me to type it out. LOL.
    3Fitty, check your little arrow button to the right of the page.
    Below is an older screen shot of my rep when it came up a few months ago. See the blue arrow gizmo on the right side? press that and see if it comes up, other than that, not sure
    Aaron
  1. How-to Access your User Control Panel (User CP)
    By Ryan L. in forum Discussion Forum Related Basics & How To Articles
    Last Post: Oct 22nd, 2008, 06:25 AM
  2. Begging for Rep!
    By 3Fitty in forum The Break Room
    Last Post: Aug 12th, 2008, 11:42 AM
  3. Meguiars Rep
    By mpbsystem in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Jul 14th, 2008, 09:10 AM
  4. Rep Power?
    By BlueTooth in forum Discussion Forum Related Basics & How To Articles
    Last Post: Dec 19th, 2006, 05:17 PM
  5. Looking for local rep
    By ZaneO in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Jan 25th, 2005, 07:30 PM
