What, if any role does Isopropyl alcohol play in car detailing? I read about it a lot (on other forums) and never see anyone here talking about it. It seems (even diluted) like something harsh to be putting on your paint, but when (if at all) would I need to use such a product on my paint?
Isopropyl alcohol
Re: Isopropyl alcohol
Originally posted by BlueZero View PostI'll use it once and a white mixed 1:1 to wipe off after I use a new polish to see if it removed swirls or filled. It should remove anything and everything from the surface of the paint.----------------------------------
I'd like to hear what others have to say about that as well. I don't wash the paint after I use it figuring it evaporates away and doesn't leave anything behind but I'm not 100% sure. It does seem like it would be harsh and I wouldn't want to do it all the time.Scott
Scott,
Just to be clear, you would do this to ensure you are doing actual scratch/swirl removal, correct? Have you experienced a situation where you used isopropyl and it revealed the scratches/swirls to still be present after you thought you removed them?----------------------------------
Correct. No, I have not had swirls appear after I had thought I removed them. I guess it's more of a precautionary measure. I hear about different polishes filling but either I haven't used any or didn't notice the difference.Scott
Alochol will not harm paint. However if you are letting it evaporate, then you haven't removed the oils from the paint (as they are redeposited).
I recommend using a body solvent similar to DuPont Prep Sol. Use two microfibers with a lot of nap. Use one to apply and aggitate the solvent and the other to wipe it off while still wet (to pick the oils up with it). If it flashes, all the oils lay back on to the paint's surface. I recommend wiping the surface two or three times to make sure all the oils have been removed.
You will be suprised at the amount of defect return that is possible (from all polishes).Let's make all of the cars shiny!
The alcohol is useful if you plan on repainting a small area or cleaming off residue from decals.
Otherwise I'd advise a better cleaner.
Alcohol will also dry out your skin and the evaporation rate will dry quickly as you use it.
Quick Detailer or a car wash would probably work better than alcohol.
Originally posted by retrofinisher View PostThe alcohol is useful if you plan on repainting a small area or cleaming off residue from decals.
When I'm working on a car, I'll do a test spot, and then wipe it down with something to remove all fillers. I mainly use a glass cleaner, and it works very well.
Alcohol has it's place within the detailers toolkit. I keep a bottle of it on hand, and use it to wipe down an area before I use any touch up paint.
Nick2008 Meguiar's Batmobile Team
2008 Meguiar's/Ford SEMA Team
2009 Meguiar's/Ford SEMA Team
2010 Meguiar's/Ford SEMA Team
I posted some comments about this topic somewhere in this thread...
1960 Corvette - How To Restore Single Stage Acrylic Lacquer Paint
I use the 91% alcohol from Walmart to remove pine sap drips. Works like a charm on fresh OR old drips. You'll need to reapply LSP on that spot after using.Heatgain (Gary)
The Irate Magistrate
Neutral & Detached
