We have terrible water in my town, which has a separate water supply from the county. One county away, Loudoun, the water is much less prone to spotting.
Looking for a solution. I have to use three chamois, because the car has to be dried immediately.
Waht do you use and has anyone tried this method I found on the web:
"Use a mixture of about 1/2 cup Borax to 5 gallons of water and rinse your car.
The Borax is a water softener and will eliminate hard water spotting. Works best
with warm to hot water since the Borax is a powder. You may also mix in a 5 gallon
bucket and rinse that way by making the mix and dumping the mix onto your car."
