#20 is a Polymer Sealant with a light amount of chemical cleaners. It is intended for use on finishes in good to excellent condition. If you are applying to a neglected finish, you should use a paint cleaner like Medallion Premium Paint Cleaner, Deep Crystal Step One Paint Cleaner, or Meguiar's Clear Coat Body Scrub, or ScratchX first.
Work in thoroughly, allow to dry for 10-15 minutes, and then remove with either a clean, soft 100% cotton terry cloth towel, or microfiber polishing cloth.
#20 isa awesome product, lasts a long time and delivers a slick, high shine surface. Most people like how easy it wipes off.
Check out the results Superior Shine achieved with #20 on this thread,
Originally posted by mike_c70 NOOB question but is this the same as a wax like NXT? Would I use it after a coat of wax or before?
#20 Polymer Sealant is a paint protectant, it is a type of wax. After you clean and polish your car's finish, you would apply a paint protectant. Waxes are paint protectants,#20 Polymer Sealant is a type of wax.
If you have a new car, or paint that is in good to excellent condtion, then after washing your car, you could apply #20 Polymer Sealant.
To your question, "Would I use it after a coat of wax or before?"
The answer is neither. #20 is the coat of wax.
Hope this helps...
Mike
what pads should i use to remove the polymer sealant or I can just use the mf cloth...... how long should the polymer sealant stays on the car before i wipe it off.
thanks and more power
TEAMMEGUIARS CAR CARE CENTER
Locations :Bonifacio Global City and Imus-K21
Tel. No. 63-2-8160821
Handphone 63-917-8213920
Hi teammwrs,
To remove the #20 Polymer Sealant, use microfiber polishing cloths if you have them. #20 wipes off incredibly easy.
As far as curing/drying time goes...
10-15 minutes is standard. When I use #20 Polymer Sealant, I apply to the entire car all at once. Then, by the time I have gone all the way around the car, 10-15 minutes have passed and I can begin removing it where I started when I applied it and continue removing it following my application path.
Hope this helps...
Mike
