Hi, I'm new to this forum and it looks pretty cool and hopefully will help.. I have a situation as where i was taking the emblems off of my Pickup, and I was using a heat gun(carefully i thought) the clearcoat yellowed out a little bit where the adhesive tape was, can I do anything(myself) about that ????
Clear coat burn
Re: Clear coat burn
Since this is your first post to the forum...
Welcome to Meguiar's Online!
If your lucky the problem will only be topical, that is only the very outer surface of the clear coat was affected. "If" this is the case then simply abrading or cleaning the surface with a paint cleaner should remove the yellowing.
If the heat changed the clear paint to yellow "throughout" the clear layer of paint then cleaning the surface won't help because the yellowing is throughout the entire layer of paint.
Easy enough to test, simply go to any auto parts store and pick up a tube of ScratchX and apply to the affected area. Apply about a teaspoon of product to a foam or microfiber applicator pad and work over the surface, put a little passion behind the pad. You may have to do this 2, 3, 4 times to see if a difference.
If after 3-4 applications you're not seeing any difference at all then the problem is probably not topical but deeper, throughout the layer of clear.
If that ends up being the case then the only thing that will fix it will be to repaint the affected area.
Re: Clear coat burn
MIKE,
Thanks alot for your help and I will try this, I do have some Scratch X, actually bought it today since I gave my sister my other tube for her new Acura TL that she rubbed against her garage......Hey is there anything else maybe alittle more abrasive ?? or is that not a good idea?? One more question where would you recommend buy the Meguiars products?? They seem to be difficult to always find here on the east coast...
Re: Clear coat burn
I have a couple of places in North Jersey, but nothing beats ADS as far as I'm concerned.
www.autodetailingsolutions.com----------------------------------
Re: Clear coat burn
Get yourself a bottle of M105 Ultra Cut Compound. There is one word that describes the results this product produces by hand or machine.
Amazing
It's more aggressive and faster by hand than ScratchX or any of our other hand-applied products. It is my go-to product for just about any pant correction problem by hand or machine.
