This is a hypothetical that I was thinking aobut.
Suppose my car has swirls and I decide to do a correction with a DA polisher and actually do it, successfully. Thereafter, assume I continue on my evil ways and swirl the car all over again and correct the problems.
If I keep repeating this cycle on the same car, will I eventually run through the clear? If so (and I know there is not a single answer for this), but how many times (average) would it take correcting a vehicle before you risking running through the clear.
I know that the depth of the clear will vary from car to car, but are there any approximate parameters of clear coat depth? Lets say for example, I was to use #83 + #80 on my IS350 once a year. How many years would it take (if at all) before I went through the clear coat?
I also know that the answer could be different if using a rotary, so I was hoping you could give me your thoughts with respect to a DA (like a G110). Thanks.
