Removing adhesive from trim
  • Removing adhesive from trim
    I left some masking tape on my trim and the sun melted the adhesive. What can I use to remove the adhesive without damaging the black trim?
    Re: Removing adhesive from trim
    I've used, WD-40, rubbing alcohol (91%), Goo Gone and Tarminator. They all do the job without damaging paint. If the adhesive is thick a plastic razor blade helps too.
    Life isn't about 'weathering the storm', it's about learning to dance in the rain.
      Do any of these damage the plastic trim? I have it all over the trim that goes around the windows.
        Any suggestions? I'm looking to use the least aggressive method first. I tried using an old clay bar and removed some of it. I was thinking about heating it with a blow dryer and seeing if it comes off.
          3M makes a product called Pinstripe Removal Wheel
          AeroCleanse, LLC
          www.aerocleanse.com
            Radkonn, I found that Meguiars PlasticX will work well, too, but you have to work it in hard. Try some of that on either a foam cutting pad or a terrycloth bonnet.
            1991 Honda Accord EX Sedan; daily driver; 0-60mph 7.625 seconds top-end of 2nd gear @ WOT.
              3M General Purpose Adhesive Remover.
                Meguiar's #39 may work. I have had some tape residue on my rubber trim and #39 cleaned that up w/ no issue.
                1999 Ford Contour SVT
                Silver Frost/Midnite Blue
                1966/2760
