Here's another test I was more or less just playing around one night to see how many applications it would take to remove or improve some swirl's and scratches by hand on a old single stage paint gas door lid off of one of my old mustangs that I parted out.
I applied 5 applications of scratchX by hand (the tube for use by hand) and using about 15 to 20 lbs pressure.
Here's what I'm starting with, all ready used some quik-detail spray to do a fast wipe down.
This picture is with the overhead light shining directly down on to try to capture the swirls and scratches best as possible.
1st application applied and removed, again applied all applications using 15-20 lbs of pressure.
2nd application and starting to show some improvement.
3rd application no change but looks to have more clarity
4th application swirls and scratches just about gone.
last application. Looks flawless, I could let it go at that but I try to show what the true condition is and it's just about impossible if not impossible to make something that is old and with as many swirls and scratches look new again.
OK, here's is after applying 2 coats of #26 by hand, it brought alot of clarity and deepth back not to mention the gloss. Taken an up-close picture with as much light as possible to show that as good as it looks there is still some deep scratches but not as badly swirled or scratched.
