I have noticed over the past couple of weeks that on my truck I have seen more and more orange peel. I was wondering if anyone knew why orange peel happens and if I can stop orange peel from worsening or spreading? Thanks for your help.
What makes orange peel occur? Can You Stop it?
Re: What makes orange peel occur? Can You Stop it?
You must just be noticing it more since you have spotted it. Orange peel can't worsen. It can be removed but like 94BMW325CIS said it has to be wetsanded to remove it.2007 Dodge Nitro SLT
Yeah, I had always seen it on mine as I posted about this week, but I didn't know it was bad or called orange peel. I was stupid, so I almost thought it looked cool. ha-ha.
***** now that is all I see, but nothing I can realistically do about it.
Removing factory orange peel is NOT recommended by most, and I highly suggest against attempting to completely remove it.
Now, with a paint thickness gauge, some common sense, a few different grits of Meguiar's Unigrit sandpaper, and a rotary buffer to buff it out you can safely take the edge off- but that's it. Any more than minimizing it and you risk causing clear coat failure.
This advice is based on my personal experience, and is not an official Meguiar's response FWIW.
Originally posted by Mark Kleis View PostRemoving factory orange peel is NOT recommended by most, and I highly suggest against attempting to completely remove it.
This advice is based on my personal experience, and is not an official Meguiar's response FWIW.2007 Dodge Nitro SLT
Originally posted by mb911 View PostYeah, I had always seen it on mine as I posted about this week, but I didn't know it was bad or called orange peel. I was stupid, so I almost thought it looked cool. ha-ha.
By the way orange peel to an untrained eye does look kinda cool.2007 Dodge Nitro SLT
Thanks a lot for your help. I think I will be getting rid of my truck in 2 years so I don't think its worth it. Thanks anyway.Joel
Typed a few comments in the thread below on the subject of orange peel and wet-sanding...
Orange Peel
***** now that is all I see, but nothing I can realistically do about it.quality creates its own demand
Originally posted by 94BMW325CIS View PostOrange-peel is actually from the way manufacturers dry the clear coat. It doesn't get worse, but the only way you can get rid of it is by doing a full wet-sand.
If any of these are incorrect you will get orange peel.
It is possible to spray with very little peel.
Factory spray booths are adjusted for quantity NOT QualityBlack Bart
