M1611 paste wax
Results 1 to 10 of 10
Thread: M1611 paste wax
    Sep 2008
    edgewood NM
    4
    14
    M1611 paste wax
    My father bought a DELTA table saw with an extension table and he was told to apply Meguiars M1611 paste wax to keep it in good shape. I can not find this item. Has it changed #'s or is there another product that would work?
    Thanks for any help!!!
    Wheels
    Formerly 101impala Andy M.'s Avatar
    May 2004
    Philadelphia, PA
    54
    3,969
    349
    Re: M1611 paste wax
    Hey Wheels,
    First off, welcome to MOL!
    M16 has been discontinued. It was an awesome product but due to regulations beyond Meguiars control, it was gone. You can still find some maybe on ebay, but I am sure some will chime in with something comparable Though nothing is as good as M16. IMHO.
    Andy
    Andy M. Moderator
    Sep 2008
    edgewood NM
    4
    14
    Re: M1611 paste wax
    Quote Originally Posted by Andy M. View Post
    Hey Wheels,
    Andy
    So do you recomend any substitute???
    Person PorscheGuy997's Avatar
    Apr 2006
    Southern Indiana
    1,344
    36
    Re: M1611 paste wax
    Any one of Meguiar's protectants will be fine.
    But, this is an industrial application. I would try some M0811 Mold Release Wax.
    Chris
    Dasher Detailing Services
    Sep 2008
    edgewood NM
    4
    14
    M1611
    Wheels
    Registered Member Markus Kleis's Avatar
    Jul 2006
    Orange County, CA
    37
    4,141
    147
    Re: M1611
    The best replacement in my personal opinion for that application would be new NXT Tech Wax 2.0, paste. You should be able to grab that locally very easily.
    60
    24,761
    521
    Re: M1611 paste wax
    Let me check with R&D on Monday...
    Hang tight...
    Sep 2005
    14,253
    539
    Re: M1611 paste wax
    You can also check e shine in Canada. Quite often they have some for sale.
    Sep 2008
    edgewood NM
    4
    14
    Re: M1611 paste wax
    Just checking to see if you had heard anything??? Thanks for trying!!!
    Wheels
    60
    24,761
    521
    Re: M1611 paste wax
    Quote Originally Posted by Wheels View Post
    Wheels
    Sorry for the delay, just sent an e-mail on this topic.
    FWIW
    There was a time I worked for Simpson's Plywood Mill which specialized on Marine Grade Plywood, the highest quality, most expensive plywood you can buy. I did a lot of different jobs at the mill but one of them was running a Patcher, (think that's what we called it), basically you would draw a sheet of veneer onto the table and then punch out and plug any knotholes in the panel. Grade A+ could have no more than 4 or 5 plugs.
    Plugs are those things shaped like a football in a sheet of plywood.
    Before your shift started and all through the night, one of the things we would do is wax our steel tables so the thin sheets of wood could slide easily which reduced the strain on the operators to move large sheets of wood across the table from the incoming stack to the finished stack.
    For this we used paraffin wax that came in rectangular bars. kind of like what you would find for sealing canning jars.
    We also used this on all the dryer tables where wood that had been through a dryer would be pulled off onto carts according to the grade of the wood. Again, the paraffin wax helped to make the large sheets of wood slide easily to reduce strain on the worker.
    We manufactured 5x11 sheets of Grade A Marine Grade Plywood and laminated sections together to make 5x20' sheets so we worked with large panels of thin wood. The cost of the wood was very high and keeping tables where the wood was moved over waxed-up was important as it helped to prevent damage to the costly wood.
    And yeah... worked on the Green Chain too...
  1. The difference between # 16 (Professional Paste Wax) and # 26 (HiTech Yellow Wax)
    By lukaszr in forum Meguiar's Retail/Consumer Line Products
    Last Post: Mar 4th, 2009, 08:35 PM
  2. Color of the M1611
    By kitkhoogetz in forum Professional Line - Product Reviews
    Last Post: Nov 29th, 2006, 12:55 PM
  3. Gold class wax paste VS NXT wax paste???
    By ericmichaelm in forum Consumer Line - Product Reviews
    Last Post: May 13th, 2006, 06:57 PM
  4. Gold Class Paste Wax vs NXT Tech Paste Wax
    By Yip Jen in forum Detailing 101
    Last Post: May 13th, 2006, 02:39 PM
  5. M1611 Professional Paste Wax
    By Jose Torres in forum Meguiar's Professional Lines - Mirror Glaze, Detailer, PRO Hybrid Ceramic & Other
    Last Post: Jun 29th, 2005, 11:09 AM
