Re: Engine Detail...No water?
Hey HK77
the alternator which is in the red circle should be covered. and also the distributor should also. The distrubutor is bout 3 inch to the left of where you have the red rectangle. if you fallow all the wires you have in the red rectangle back to the left you will find the distrubutor. what you have in the red rectangle should be ok if they havenot been removed withn the past week or so. Hope that helps
Hey HK77
