There appears to be some confusion over Meguiar's NXT Spray Wax. Recently I have been reading posts on other forums that indicate that some people are under the impression that the NXT Spray Wax must be used with the NXT Tech Wax as a sort of system.
This is not true.
NXT Spray Wax is an option, not a requirement.
Just like our spray wax in the Consumer Line, Quik Wax
Meguiar's NXT Spray Wax is a maintenance product that can be used in-between a regular application of a normal wax and washing, or after using a quick detailer.
Both of Meguiar’s spray waxes, NXT Generation Spray Wax and Quik Wax are for restoring that just waxed look quickly and easily. Both of these products add richness to your cars finish. They both restore gloss, shine and slickness.
Part of the confusion I think, (from posts I've read here and on other forums), may come from the word/term, Booster Wax.
Since I coined the term first on 2-3 other forums, in threads dealing with Meguiar’s Quik Wax, let me explain the meaning and idea behind the term.
There was a thread on another forum where a person purchased and tried Meguiar’s' Quik Wax and then complained that it didn't work. I chimed in on the thread and found out that the person using this product was using it on a car that the finish had been neglected.
The car's finish needed to washed, clayed, and then have either a cleaner/wax or a multi-step system used on the finish to restore it to an acceptable standard. The person that purchased this product was under the impression it was a wax like most waxes on the market and could be used as such.
This couldn't be further from the truth. Spray waxes like Meguiar’s Quik Wax and NXT Spray Wax are not replacements for cleaner waxes, or any traditional wax found a bottle or can, nor are they formulated to remove above surface contaminants, (Like a clay bar does), or remove oxidation, road stain and imbedded dirt, or other surface contaminants like a paint cleaner.
The reason the person was not happy with the product was because it was the wrong product for the job. Meguiar's spray waxes are for use on finishes that are already in excellent shape and already have a good base coat of wax. When used on a finish that fits this description, they both work excellent.
After explaining the above in this thread on another forum, and in other similar threads, I began thinking of a way to explain how this product is intended to be used with a few words, which could be used on the front label. The words I came up with were, Booster Wax.
The idea being is that this is a product that can be used to boost, or renew the previously achieved results, quickly and easily by simply misting this product on, spreading it around and the wiping it off. With a little practice and technique, this product works excellent to restore that just waxes look to your car's finish.
That's all there is to it. Some people have tried to define what this product is for other than what I have explained above, and others have implied it's a necessary component of the NXT Tech Wax as in a system.
While these two products do compliment each other, and they are both chemically compatible, you do not have to use the NXT Spray Wax with the Tech Wax in order to get the benefits and features of the Tech Wax.
I hope this helps explain the positioning of this product and the term booster wax.
NXT Generation Spray BoosterWax
Mike
This is not true.
Mike
