One last question about the #16. I am going to apply it by hand (very thinly) as was suggested, but can I use my 6 inch random orbital buffer with a terry pad to remove the haze?
Thanks for all of the help and your patience.
Dianne
Dianne
That should work just fine. Just make sure the terry on the buffer doesn't leave marring. I've found the grades and softness of terry can really vary.
One goofy trick I've used a few times is place a microfiber towel over the orbital head. Then just use that to remove the wax. You have to be careful that the towel doesn't get away from you but it really works pretty good.
If you apply M16 very thinly then you might be able to remove it by machine. Might just depend upon how much power your polisher has. ( I've always removed by hand so I don't know if you can remove by machine from first-hand experience)
This is something you could test when you do your test spot to a small section.
Please update this thread with what you find out.
You've got #16 ... not what?
Now put it on your car ...
Yes, it's old-fashioned and yes, it has a peculiar method of application but it leaves a great glossy finish that I reckon is quite hard to match. I often use #16 as a final coat on top of other waxes - what #26 does for depth, #16 does for the gloss. I like it after a simple Autoglym Super Resin Polish spruce-up and I like it after half a dozen liquid waxes I could mention.
Why? The beading is superb and the finish seems to remain after the car is covered in dust and washed off.
Someone asked about topped NXT Tech Wax with it ... why not? Try it out and see if you like it - NXT does quite a lot of things for paint and beading is not one of them in my opinion and experience. Light swirl filling and depth is what it does reasonably well and you can improve that finish with a glossy, beading wax ... #16 fits that bill.
Surely it's about time Meg's re-worked this and made it VOC compliant? I'm in the UK, so we don't have such problems with getting hold of the wax. I know Meg's are touting the NXT wax as their finest, but given how much of a following there is for #16, surely it's worth considering and re-working?
My two cents -- I think that beading is not something that you really want all that much. Consider a black vehicle sitting in a parking lot after a rain. The sun comes out and the temperature goes up to 80 or 90. You have water beaded up on an already hot hood. Water spots - ""! Not something that I want. I want a wax/sealant that sheets off water ASAP. But then I'm and "old guy" who used to love the beads that showed up on my well-waxed vehicles after a rain. I also liked the "ohs and ahs" that I got when folks saw the beads. I guess that wisdom has finally come with age.
And if you think that # 16 is hard to work with, let me tell you about the original Cadillac Blue Coral.
Is #16 cool? Sure is. So was my black 1964 Chevelle SS 327 that received a fresh coat of the stuff every month. However, the water spots that formed after a rain were not all that cool.
How does #16 compare to #26? The reason I ask is I still think #26 produces a much deeper and better shine then any of the newer products, yet I have never tried #16. Mabey I should get myself a can of #16 before it's too late!
M26 tends to darken the paint and give it a ton of depth.
M16 just has a certain shine to it that's hard to put into words.
That being said, is one better than the other? Well, not really. It's pretty much about what you think looks good. In my opinion, M16 is one of the best waxes ever made (why do you think I had more than sixteen tins at one time). If you haven't tried it, give it a shot. M16 isn't too expensive, yet.
Better is most subjective - there is, for example, a difference between volume and loudness ... and that's the difference. #26 gives depth and #16 gives gloss.
Tom
As another old timer who's first brand new car was a fire engine red 1964 Malibu SS, (283ci, BTW, I think the 327 came in 65) I also used Blue Coral on it and can say I've never used a harder wax to remove even if applied thinly. LOL. Fortunately water spots didn't show that much on red. I replaced it with a 66 SS396 a couple years later that was black and quicky switched to another wax. I seem to recall it was Vista.
