Equipment Cleaning
  • Equipment Cleaning
    How/how often do you guys clean all your equipment? Do you clean your buckets and grit guards after each wash? Do you put your mitt in the washing machine or just rinse+hang dry it? What about the other stuff? I'm talking about for your own personal vehicle BTW. Obviously, your company has more streamlined cleaning methods. Thanks!
    -HealthyCivic
    Check out the glossary
    Re: Equipment Cleaning
    I rinse my bucket and grit gaurd after every wash. Every so often I'll spray some APC in and let it soak with my wash mitts. Depending on how bad the Jeep was I'll wash my wash mitts every time or at least every other time. Mitts go in the washing machine then sit on a drying rack to dry. Microfibers get washed mostly after each use.
    Scott
      Yeah, I rinse buckets/grit guards.... more or less hand wash the mitts, wash/dry MF towels in the machine, then seperately terry cloth ones.
        I rinse my buckets out (and grit guards) PRIOR to each use to make 100% sure it didn't get dusty or contaminated while stored.
        As for cleaning other stuff, I try to clean my pads the night I finish on my Padwasher 2000.
          I'll clean the buckets and the grit guards after a detail and before he next detail session starts. Hand wash all the mitts and the yellow applicator pads and hang to dry. MFs - machine wash. Pads (old yellow/maroon/tan) washed by hand/Padwasher and new ones (2.0) in the machine.
            I don't clean the buckets/grit gaurds after a wash, just before the next wash, no need to waste the water to do it twice. I wash my microfibers and mitts whenever I need too, I have about 100 microfibers and 5 wash mitts, so I can do about 7-8 cars before I need to wash everything.
            Ryan
              I generally try to wash everything after the days detail is done.
                Cleaned the buckets after using them ensures the chances of dirt/other contaminants not being stucked to the bucket and/or grit guards. Cleaning the buckets (simply rinsing them- fill small amount of water in, dump water out) is to ensure no sand/dust in the buckets before starting the washing session (thts before I got my gamma seals). Very dusty at my place here. MFs - I've clean them after every session eventhough I have around 2++ pcs of them. Faster you get the dirt out, lesser risk of it being stucked in the fibres.
                  I rinse and dry the grit guards and buckets right after I finish. If I used my G110 I disassemble and put it back in it's case. I try to save up MF's to get a decent size load, but will wash only a couple of wheel MF's by themselves to prevent cross contamination.
                  I examine each MF as I take it out of the washer to make sure there isn't any contamination stuck in the fibers then hang them on plastic clothes hangers to dry. After they dry, I fold them and put them in marked ziplock freezer bags.
                  My wife tells me she's thinking about having me committed.
                  Mike
                  George Carlin
                    I wash/rinse my bucket when I'm done, I just reuse the water and soap that is left and wash it with it.
                    My wash mitts and MF towels I wash it the same day as well
