I received three samples to try out and post my findings. This review is for 21-09B by hand vs 2500 grit sanding marks. I was told this is for removing moderate to heavy swirls, scuffs, stains and oxidation. It does not contain any LSP. Methods of application are hand, orbital or DA polisher.
My first test was by hand on the same panel and same sanding marks I tested M105 on. (That thread can be found here.) I will be posting another test using the G110.
Here is a photo showing the state of the panel before. The sanding marks on the left are from 2500 unit grit paper. The marks on the right are from 600 grit paper. I just want to point out that when I did the 600 grit sanding it ended up getting quite a few deeper marks. These marks were tracers from the grit coming out of the paper and working into the clear.
Here you are looking at the results of an application by hand using the yellow foam Meguiar’s applicators. The area above the tape is from the M105 test. I did a 50/50 IPA wipe down of the area before this photo. I also did a wipe down of the M105 area just to see if that would change at all. The light is a 500W halogen. I taped off the 600 grit area because I didn’t want the tracers to interfere with the real test results. However if you look over to the right, it did a very impressive job. Judging by these results I’m wondering if this isn’t a DA friendly version of M105! I was very impressed with the results. I would say it's a bit wetter than M105 but not as much as M95.
