NXT 2.0 or Deep Crystal (or both)
Results 1 to 10 of 20
Thread: NXT 2.0 or Deep Crystal (or both)
    Registered Member Paolo80's Avatar
    Oct 2008
    Sydney, Australia
    26
    12
    Hi ppl,
    im quite new to car detailing, hopefully some1 can help with a pretty simple question i have.
    I just purchased the clay kit and NXT 2.0. Let me start by saying, SUPERB products.!!!! I really don't care what any1 has to say these products do what they say and are so easy to use.
    I have a '00 model BMW 323ci the color is SKARAB GREEN, it's a limited factory color that well i havn't really seen another one like it around yet, it's a dark greeny-purple-greyish color, it has been neglected in the past, although it's not so bad i'd like to get it back to it's peak.!
    I cleaned it over the weekend using Hyper wash > then used the clay kit > then the NXT 2.0 remarkable results although looking verrrry closely into the paint it has faint web marks and blemishes id like to get rid of.
    The question finally is, im not sure if the NXT 2.0 is the polish that i need, or shuld i - Hyper wash > Deep Crystal Polish > NXT 2.0 to protect it all.???
    and possibly even throw in some ScratchX in the process somewhere.? lol
    Sorry for such a long post. i look forward to some good old professional advice.!!
    Jul 2006
    Orange County, CA
    36
    4,138
    145
    Re: NXT 2.0 or Deep Crystal (or both)
    Welcome to MOL Paolo! You are very right, they are great products that even pros reach for daily (myself included).
    As for what else you need, it does depend on how bad (or not) the scratches and webbing are, and also what tools you have available. Do you have a polisher? Meguiar's G100 or G110? A Rotary?
    If not, your best bet would be to follow your next wash with some ScratchX by hand. You will want to use a clean soft buff foam applicator, and don't be afraid to put some "oomph" behind the pad (or passion as Mike Phillips likes to say!).
    Then, once you finish that you will want to re-wax the vehicle since the NXT 2.0 will be removed by the ScratchX.
    Oct 2008
    Sydney, Australia
    26
    12
    Thanks for your prompt reply Mark.
    Unfortunately i don't have access to any mechanical polishers.. it's every bit elbow grease from here on in..!
    I'll try and upload a clear picture as soon as i can this way you can get a fair idea of the work needed. Overall the paint is not in a poor condition, but it's also not perfect, i'd like to get it as close to perfect as possible.
    As for the NXT... do you recommend using NXT 2.0 or the Deep Crystal.? or both one after eachother.??
    Jul 2006
    Orange County, CA
    36
    4,138
    145
    DC wax and NXT 2.0 are both great waxes, but I believe that the NXT 2.0 is generally believed to last longer. Since you have already cleaned the paint (and the ScratchX will even more) I would go with the NXT 2.0 personally.
    SHAKEN 03mach1's Avatar
    Mar 2007
    Nor Cal
    29
    1,495
    28
    Use NXT 2.0 it is an amazing product and produces dramatic results. It is my personal favorite.
    Alex
    1972 Dodge Dart Swinger360
    1998 SVT Cobra 1 of 551
    1969 Ford Mustang Fastback
    Oct 2008
    Sydney, Australia
    26
    12
    kool..sounds like we got a winner...
    So it would be right to assume the NXT is both a polish and a protective wax coat..?
    I had somehow thought the DC gave a deeper polishing effect hence my original question.
    Also by spraying the Quik detailer after lets say a few days to clean any 'roughness' or dirt/dust over the car with a microfibre towel would that remove the NXT polish.?
    Jul 2006
    Orange County, CA
    36
    4,138
    145
    Quote Originally Posted by Paolo80 View Post
    NXT 1.0 and 2.0 are actually both sealants, which for all intensive purposes would be like a wax. They are not intended to be worked into the paint in an effort to remove actual defects. They might very well hide some of the defects (They are pretty good at filling), but they are not intended to actually REMOVE the light damage.
    As for using QD, you want to make sure when you use this that you are only removely light contamination such as dust or fingerprints because you can cause marring on the paint if you rub heavy dirt into the paint. I just wanted to clarify because what you described (roughness, dirt) would be too much for any QD spray. As for removing NXT, any time anything touches the surface you theoretically are likely removing some small amount of the wax, but it is to be expected and not a problem.
    Oct 2008
    Sydney, Australia
    26
    12
    Ahhhha.. ok that now answers my question ..
    In a case where i want to get the paint to look at it's possible best. what products would you recommend i use.?
    I definitely agree with the marring, i wouldn't dream of wiping the surface with excess dirt or grime, jut light dust i imagine, atleast until i get a proper car cover . Just to let you know the NXT 2.0 im using is the liquid form in a bottle if that helps any.
    I guess my major enquiry here would be as i mentioned above, ideally i'd like the paintwork to look it's best, and then using NXT 2.0 to seal and protect it from any future damage..unfortunately the prev. owner didn't put as much thought into it as i am lol.
    Sep 2005
    14,242
    537
    Since your doing this by hand i would definitely get the scratch-x. Then when finished make sure you rewax the areas. Do not be discouraged, it will probably take a couple of passes with the scratch-x.
    Good luck.
    Oct 2008
    Sydney, Australia
    26
    12
    Would i need to polish after the scratch-x then wax with the NXT 2.0..? or is scratchx a polish..? Sorry guys just trying to wrap my head around all the different products ..gets a bit confusing..
    Also, this may sound like a stupid question, but how long am i supposed to leave the NXT 2.0 on to 'dry' before i wipe it down with the microfibre towels
  1. deep crystal and NXT wax
    By zippo2341 in forum Meguiar's Consumer Line Products
    Last Post: Jul 20th, 2008, 07:39 AM
  2. Deep Crystal 3 Carnauba over NXT 2.0
    By spatel in forum Detailing 101
    Last Post: Mar 7th, 2008, 03:39 PM
  3. NXT over Deep Crystal?
    By davisinla in forum Detailing 101
    Last Post: Dec 26th, 2005, 06:40 AM
  4. Deep Crystal vs. NXT
    By DoctorB in forum Meguiar's Consumer Line Products
    Last Post: Jun 29th, 2004, 11:43 AM
  5. deep crystal &NXT
    By tasdisr in forum Meguiar's Consumer Line Products
    Last Post: Mar 14th, 2004, 10:21 PM
