Ultimate Compound
  • #91
    Re: Ultimate Compound
    Originally posted by Rusty Bumper View Post
    Thanks to both of you.
    So you really like the G110?
    I'll have look into getting one of these machines as soon as the economy picks up.
    Honestly, I haven't even NEEDED to reach for my G100 for a while because of the power of this stuff by hand. Absolutely the BEST compound I have EVER used PERIOD!
    WTG Meguiar's, you have outdone yourselves this time for sure!
    2015 Fiat 500 Abarth.
    2011 Nissan Sentra SE-R Spec-V using AMSOIL synthetics. Best 1/4 mile: 14.959 (sold)
    • #92
      That is truly amazing.
      I saw some at Wal-Mart the other day, so I'll be pickin' it up soon.
      r. b.
      • #93
        I have purchased wolfgang polishin pal for applaying the ultimate compound. It follows with three diffrent polishing pads and i am unsure on which one i should use with ultimate compound.
        http:// www.autogeek.net/polishing-pal.html
        can i use the orange pad? or will it bee too agresive?
        • #94
          Welcome to MOL, Madfish!
          The orange LC pad may be too aggressive, depending on how hard your paint is, how bad the defects are, etc. You may want to start with a pad one step down from there.
          By the way, I disabled the link in your post as we don't allow clickable link during the first 30 posts for new members.
          • #95
            my car is an blue metallic audi a3 8l 2000 modell and i geas it have pretty hard paint.
            But i have used ultimate compound with the orange pad before, and i still have alot of swirl marks and i have i feeling that the pad leaves behind some of them:s
            • #96
              Hi Mike,
              I just wondering how does this Ultimate Compound compare to M85 Diamond Cut ?
              Also will it be okay if I use the Ultimate Compound with rotary buffer running on only 1000rpm ?? I dont have a DA :P
              Thanks Mike
              • #97
                I have the same idea with you. Great! Thanks for sharing.
                Glad to hear you're using this: I plan to keep it much more aggressively up-to-date than has been the case in the past, but don't hesitate to let me know if you find errors or need clarifications.
                Simulation pret personnel en ligne, Calcul taux pret personnel en ligne, Financement et demande credit personnel
                • #98
                  Try stepping down to either the LC white pad or a Meguiar's W8006/W8207 yellow pad and see if that eliminates any marring you may be getting from the orange pad.
                  Originally posted by TuLaLiT View Post
                  Hi Mike,
                  Thanks Mike
                  Ultimate Compound is not as aggressive as M85, plus M85 is a diminishing abrasive compound designed to do some pretty serious cutting - like removal of 1000 grit sanding marks with a wool pad on a rotary buffer. It's great for use on high solids (low solvent) paint, which was basically it's design intent. Ultimate Compound uses SMAT technology and is formulated into a consumer friendly liquid designed for removal of heavy oxidation and swirls, either by hand, orbital or D/A polisher.
                  You'll notice we don't mention using a rotary buffer with UC. Many have done so and have reported good results, too, but we did not design it with that application method in mind. You are certainly welcome to experiment, and it isn't going to do any harm - it just might not behave the way you want it to or give quite the result you're after. Then again, depending on the paint, it might be fantastic! As mentioned, since we did not develop it for that application method so it was not tested that way; testing that would normally cover a very wide range of pads, paints, etc that would then cause us to make specific recommendations.
                  • #99
                    Meguiar's Ultimate Compound is highly effective, and one of those few products that delivers on all the claims it makes on the package. I have a 2003 Corolla that I never waxed, and the hood had become very rough and dull-looking. I finally decided to do something about it before the paint became damaged beyond repair. I tried three different polishes today, none of which got rid of the dullness. I was afraid to try the heavy-duty polishing compound that comes in a can, so I looked for something else and found Ultimate Compound. It worked beautifully -- the hood is glossy and smooth again! I'm going to put down a glaze next, and then use some Meguiar's Spray Wax I bought earlier. I highly recommend Ultimate Compound if your paint is dull and oxidized.
                    • Re: Ultimate Compound
                      Hi Guys:
                      I'm fairly new to the process of car detailing and such, and I've got a question regarding UC...
                      I have a 1992 Integra with fairly good paint... some oxidization on the top and some spots on the hood... lots of micro-scratches all over the car and some more noticeable deeper ones as well...
                      I'm thinking about using UC or ScatchX.... which do you recommend?
                      Also, I want to use the 3-step direct deep crystal system before I hit my car with a nice coat of wax.
                      In what order do I apply the products? I know that the 3-step system is labeled, but when do I apply the UC/ScratchX? I would assume after step 1 (the paint cleaner), but I could be wrong. What do you guys suggest?
                      Thanks for the advice in advance!
                      -dd
                        Originally posted by dripdark View Post
                        Hi Guys:
                        -dd
                        Welcome to Megs online!
                        You may wanna pick up some SwirlX and try that before you use the UC. Use the least aggressive product to achieve the results you are after.
                        As far as to when you would apply these products it would be as follows:
                        Wash
                        Dry
                        Clay
                        SwirlX or UC
                        DC#2
                        NXT or DC#3
                        The Swirlx and UC are paint cleaners and are more aggressive than DC#1. No need to use DC#1.
                        Hope this helps. Good luck!
                          Hi!
                          When using a DA polisher, what speed are you running?
                          And do you use the yellow 8207 polish pad or the burgunder w7207 cutting pad?
                          My car is a 00 VW Golf.
                          How many passes do you run?
                          Thanks ppl
                            soiser, welcome to MOL!
                            When doing defect correction you want to use the yellow polishing pad (W8207 or W8006) on speed setting 5 on the D/A. Use firm pressure on the pad, and confine you work area to about the size of a microfiber towel. How many passes you need to make will depend on the liquid you choose, how hard the paint is, and how severe the defects are. What might take a single pass on one car may require 3 passes on a different car.
                              Thanks Michael!
                              How hard is the burgunder pad, my local Meguiars dealer said they don't recommend it with Meguiars products? I have never tried the UC som im a bit insecure wich combo im going to try out.
                                Our burgundy pad is not recommended for use with the D/A polisher, but it works great with many of our products with a rotary buffer.
                                If you're going to use UC, and we highly recommend it, use it with our yellow polishing pads on speed 5 with the D/A. Firm pressure, small work areas, and move the tool slowly over the paint. Take your time.
