W8207 - Washable Foam Polishing Pad
  • W8207 - Washable Foam Polishing Pad
    Key Features
    • Exact same foam as current W8000 series foam
    • Eliminates minor surface defects while restoring gloss
    • 7" pad combined with new technology provide a smooth buffing experience
    • High tech laminate provides durability and is machine washable
    • Recessed backing for easy centering
    • For use with rotary or D/A polisher
    NOTE: We will continue sell all of our current foam pads, no changes to them, in both the 8" and 6.5" versions.
    RECOMMENDATIONS: When using our D/A, we still recommend against the 6 speed setting for now. We know people will still operate these types of polishers at this highest setting but keep in mind that even with a D/A Polisher, at the 6.0 setting you can create too much heat if you're not careful.
    Part Number: W8207
    MSRP: $14.00 each (U.S.A.)
