Paint Cleaner?
  • Paint Cleaner?
    I have read some threads that have some great info in them
    I have a question regarding paint cleaner.
    I have read that clay bar removes contaminants that are ABOVE the surface.
    Paint cleaner removes contaminants BELOW the surface.
    To my understanding, paint cleaner works like a polish (removing very small portion of paint on top).
    Therefore, after washing + clay bar, may we skip the paint cleaner step and do the polishing step (with a pure polish) and proceed to the wax step?
    I noticed that after paint cleaner step, the pure polish step is listed as optional.
    Would I be damaging my paint and finish if I polish without cleaning using paint cleaner?
    mujjuman
    Re: Paint Cleaner?
    You do not need to use a Paint Cleaner, there is no harm is going from Clay straight to polish and/or wax. If you do use a cleaner you will take your final look to that ''next level'. Hope that helps!
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
      Re: Paint Cleaner?
      Yes it does help! Thank you!
      mujjuman
        Re: Paint Cleaner?
        Hi, Mujjuman. As I understand it, the difference between a paint cleaner like DC1 and a pure polish (e.g., DC2 or M07) is that the latter does not remove paint, oxidation, or below-surface contaminants; a pure polish does not effect any paint correction and does not prepare the surface for more effective bonding with the wax that will be subsequently applied. A pure polish is applied purely for aesthetic reasons.
        --Al Kimel
