Polishing Tape Line?
Results 1 to 9 of 9
Thread: Polishing Tape Line?
    Registered Member seanbreaux's Avatar
    Feb 2008
    Los Angeles
    34
    Today i taped some painters tape down the center of the hood of a lexus gx470 so i could compare the results when polishing. I polished with a g-110,a 7006 pad and m83 on speed 6. I took the tape off and now i have this line down the whole hood on the side where i polished. I guess i took off enough paint to make a visible line. Has anyone had this happen? I went over the line several times with the same combo and it is still there. Suggestions
    Here is a pic. Its not the best but you can see the line right in front of my finger.
    2003 BMW X5 4.4i
    Registered Member BBoe's Avatar
    Aug 2008
    Monterey Park
    8
    12
    Re: Polishing Tape Line?
    Are you using a clean/fresh pad when you are trying to remove this line? Seem strange for the same combo not to work if its not the method has been changed somehow.
    Jul 2008
    Burbank, CA.
    137
    17
    I'm guessing the paint was in real BAD shape, to be using a cutting pad on a DA? I think the version 1.0 cutting pads were not to used with a DA because of the scouring it does?
    Cranking a DA up to 6 also is not recommended, because of the heat it will generate in the pads backing velcro?
    If you've use the same technique on the non-test spot to even out the area and it's not working... I'm at a loss at what to tell you. M105 could be the hero of the day, if you had some. Great for using by hand. If you are going to be using your DA with M105, use a polishing pad only and at speed 5. If you start to notice dusting, you've worked it too long. M105 does it's job quickly.
    (Meguiar's does NOT recommend a DA with the original M105)
    Feb 2008
    Los Angeles
    34
    Quote Originally Posted by TerryAdams View Post
    Bad is an UNDERSTATEMENT. I don't have any 105 unfortunately. I am going to keep trying the same combo if it doesnt work i might get some 105. The cutting pad marrs the paint pretty bad but i follow it up with a 8006 pad with m80 on speed 5 and finish it with a 9006 pad on speed 5 with color x and it looks really nice.
    2003 BMW X5 4.4i
    Aug 2008
    Monterey Park
    8
    12
    I just noticed that you said you were taping to compare results. What was it you were comparing to? A untreated spot or comparing between different products?
    I also think that combo you are using is kinda extreme. That's not saying its a bad combo but why did you need this much cleaning power?
    Edit-Could it be a problem with the fact that the area was taped (glue)? What I mean is maybe you should try to wash it and clay it then redo your combo and see.
    Last edited by BBoe; Nov 13th, 2008 at 10:03 PM. Reason: You posted while I was typing up my post.
    59
    24,767
    519
    Quote Originally Posted by seanbreaux View Post
    Yes. Not a a fun result to see in some cases and teaches you to be careful with doing test spots.
    The only way to fix it is to level the paint flat and just like removing any below surface defect there's always a certain amount of risk involved.
    In one case I wet-sanded the tape line flat and then removed my sanding marks. In other cases simply machine polishing enough did the trick.
    Another option is to rub the line out carefully by hand using M105. See these threads that discuss the Popular Tag exert.
    Be careful.
    Feb 2008
    Los Angeles
    34
    Be careful.
    Thanks Mike,
    I will keep trying CAREFULLY. I will post how it turns out. I think i will lay off the taping for comparison for a while. You learn something new everyday.
    2003 BMW X5 4.4i
    Jul 2008
    Burbank, CA.
    137
    17
    Taping off for "Befores and Afters", are a good thing. Perhaps just start slowly, next time, ie. M80 with a Polishing pad test? On the picture posted, it looks as if the paint is cracked very deeply, in some areas. I wish you luck on making paint the best it can be.
    Feb 2008
    Los Angeles
    34
    Ya it was left outside a lot so the birds got to it. Im not trying to make it perfect just a lot better.
    2003 BMW X5 4.4i
  1. pro line/consumer line differences
    By hobby11 in forum Detailing 101
    Last Post: Mar 3rd, 2009, 06:47 AM
  2. Replies: 3
    Last Post: Mar 18th, 2008, 01:14 PM
  3. cross ref pro line to consumer line products
    By ronniejay in forum Detailing 101
    Last Post: Dec 7th, 2006, 12:53 PM
  4. Sanding a clear coat tape line
    By BabyBigfoot in forum Sanding Automotive Paint - Hand/Machine
    Last Post: May 13th, 2006, 03:13 PM
  5. Replies: 5
    Last Post: Jul 23rd, 2005, 04:08 PM
