[How to] Remove Waterspots from Molding/Trim
  • [How to] Remove Waterspots from Molding/Trim
    Before.
    After.
    So I just bought my Honda Fit this past February, and I love everything about it except that I drive it so much it constantly gets dirty. About a month after I purchased the vehicle it got sprinkler water on it, and I didn't wash it for about 3-4 weeks after that happened. Now I know I should have washed it right away but I really didn't think it would get this bad. It just so happens I had Marine RV #47 Hard Water Spot Remover in my line up, so I figured what the heck, ill try it out. And since it was so easy, I made a How to for all you folks with the same problems. Side note, this should work for more than just your trim/molding, but I only tried it here.
    Items Used:
    Marine RV #47 Hard Water Spot Remover (Mine came in a spray bottle.
    Microfiber Towels (I didn't use these exact ones)
    Last Touch Detail Spray (I Love this stuff)
    Time Required for this job.: 20minutes
    1. This is what I had to start with, so I first started by washing the car.
    2. I pretty much followed the directions on the bottle, spray on the infected area. (it says to let the spray set for 20-30 seconds, but it also says do not let product dry.) Since I was working in the shade I let the product set for about 2-3 minutes to really let it work in.
    3. Wipe off product.
    4. Inspect results. I was pleased with the first round, but I really wanted to try to remove more of the water spots. So I re applied, and this time I applied it to the whole right side molding of the car.
    5. After the second application I was happy with the results. I proceeded to spray the areas I worked on with Last Touch Detail Spray 1:1. (If you are working on a majority of the car I would recommend washing the car again.) The bottle says you can just wipe the #47 away, but it didn't seem that way for me. And here are the results.
    Can't see it that well, but this is the whole side I did.
    Next Area I need to work on.
    Schotography
    Re: [How to] Remove Waterspots from Molding/Trim
    Great write-up and results! I didn't know the Marine Line had that product. Great, another product to order..haha
      Nice tip. I have to keep that in mind for the BMWs I do
      Hello, I am Isaac
        Great tip. Thanks for taking the time to write it up for us. Thanks for sharing it. I will definitely remember this one. Thanks again.
          I have that problem. Really good to know. Thanks for sharing.
            Thanks for the tips. Nice write up and pictures.
              When I used All Season Dressing it covered up the spots, not sure if it removed them, but they are no longer visable.
              AeroCleanse, LLC
              www.aerocleanse.com
                SYDSTER
                  Awesome results!
                    Nice job....
                    Skoda Roomster
                      big ups to you for sharing this with us and even a better idea
