Re: Will Zaino Z2 bond to M09 or M80?
No, you follow a harsh/compound/polish with a medium or fine polish as it is a step less aggressive and it abrades away the rough surface from the previous step, leaving behind smaller scratches...sometimes so small you can not see them (with fine polishes).
Have you ever worked with wood and sandpaper? It is common to start with an abrasive sandpaper such as 80 grit (meaning 80 particles that cut per square inch), which takes lots of wood out with each pass, but leaves many scratches. Next, you would follow with something like 120 grit, then 220, 440, etc until you reach a finish that is suitable for your tastes and application.
Same concept applies to paint. You start with more aggressive products and work your way back down to fine products that leave the finish smooth and glossy.
Again, to clarify, a finishing polish IS an abrasive product, albeit very gentle. It is intended to remove fine scratches, leaving such fine scratches that you will not see them at all, but instead see a flawless and glossy finish.
Originally posted by Boba
View Post
View Post
