Hi GUYS!
I'v read over some other threads and have been very helpful. But i was hoping to get some definite answers for what I must do.
THIS MIGHT BE A BIT LONG AS I WANT TO GIVE AS MUCH DETAIL AS POSSIBLE.
I have just finished respraying a signly stage acrylic urethane (RED).
Now prior to doing so i spoke to a friend who is a spray painter and suggested to put 6 -7 coats on it in order to have sufficient paint in order to wet sand smooth.
Therefore, there is approx 7 - 8 coats of paint that is hitting 2 days old and is a little bumpy with evident orange peel.
I know that i must wet sand.
I was going to start with 1200 grit --- > move to 1500 grit and perhaps even as far as 2000 grit.
Im not after a show finish its only a 4x4 daily bash around. and i was even considering leaving the paint as is, a dull finish but i think it could be improved.
After wet sanding i belive that the panels should feel smooth as? is this correct. without any orange peel etc...
Now once i wet sand all panels what do i do from there on.
I have an electric buffer with only high / low switch and has a wool pad on it at the moment.
(NEVER BUFFED BEFORE)
WHAT PRODUCTS DO I USE?
WHAT STAGES?
and is wetting the surface whilst buffing a good idea to stop burning the edges?
I was hopeing to do this very soon as it will be easier to manage the paint prior to completely curing.
ANY DETAILS WILL BE VERY HELPFUL.
THANK YOU ALL IN ADVANCE.
ALSO THE BONNET IS OFF THE CAR SO I AM WILLING TO PRACTICE ON IT AND IF I STUFF IT UP I CAN SAND IT BACK AND RE SPRAY IT AGAIN.
WHAT STAGES?
