Re: Your Daily Driver: A Simple Wash & Wax Regimen
Sure, you can go straight to wax after claying, if you prefer. Many in fact do.
The benefit of the cleaner wax is that is helps to remove stains and below-surface contamination that claybar cannot remove, and it provides an initial layer of protection. You can then top it with your favorite wax/sealant, thus securing the two layers of wax protection that Meguiar's recommends.
There is absolutely no need to wipe the car down with Prepsol after applying a cleaner wax. That defeats the whole purpose and simply adds an additional and unnecessary step in the process.
Compare Meguiar's 5-Step Paint Care Cycle. They recommend the use of a paint cleaner after claying. After this two coats of one's preferred wax/sealant is to the applied. In my simplified process, I remove the dedicated paint cleaner and and substitute instead an AIO product (some kind of cleaner wax). After the AIO you might choose to stop and congratulate yourself on a find job done, or you might want to add one more protectant coating of the wax of your choice.
