Gilmour Foamaster Adjustable Multi-Ratio Cleaning Gun #75QGFMR
Prior to the purchase of this I wasn't too sure about the foam gun, so I thought I would give those looking into on a little closer look out of the box.
I bought the gun off Amazon for around $35 and as usual free shipping. The hope is that this will save some time in washing my vehicle, at times it can get a little much washing my Avalanche as much as I do and I hope this will help make things quicker.
What you get:
Ratio Markings/Settings:
Filter Screen:
Quick Connects:
I can see this being very handy for rinsing prior to the 'foam down'. I will be adding a quick connect to the hose end to easy change over the the flooding rinse method.
Ratio Setting Adjustment:
In addition to the slidding adjustment there are a couple thumb screws on the main brass body in this photo... I would assume these will fine tune the flow by changing the amount of air entering the foam. You can also rotate the sliding tube to turn the foam on and off.
The Setup:
Yes, so I can't spell.
This seems like a very solid unit, well designed and built with lots of solid brass and heavy duty plastic. I have yet to use it, just waiting for some better weather and you bet the second the weather turns around I will be out testing this thing!
