Re: A closer look at the Gilmour Foam Gun....
You have the Gilmour model with the brass slide?
I put in 4-5 ounces of soap, fill to the top with water use the highest setting (biggest hole in the stem), and that is enough for my car. You'll have to try it and see. But that gives a good soap ratio, even if you got lost in the math. Pretty much the same as for a bucket.
I spray a panel, or half roof, half hood, etc... spray the mitt, and wash the panel. Flip the mitt over, spray the panel, and spray the mitt. Then wash, and then rinse in my rinse water bucket. Then continue.
If you get into presoaking, of course you may use more.
