Hello. I’ve been a lurker here for a long time, but I believe this is my first post. I have a couple questions about which products and pads I should use with a rotary. First off though, I’m not looking to do this for a living, but rather want to improve the finish of my own vehicles. I’ve actually been wanting to get started with this for a couple years now and had planned all along to start out with M80 and M83. Then Meguiar’s had to go and confuse me with their new products last year. So, after reading all the reviews here, I decided to start with D151.
To date, I’ve really only attempted to correct one vehicle and that is my wife’s dark red 2000 Explorer. I used D151 on a Meguiar's W8006 pad with the G100. While I am by no means an expert with the G100 I have watched the “How to Use the PC” DVD by Mike and Richard several times. So, I’m fairly confident in my technique. I was able to improve the finish quite a bit with this process, but there was still some cob webbing and swirls when I pulled it out into the sun as well as some RDS. It also took quite a few passes and I only did the hood so, I’m assuming that the Explorer has some fairly hard paint.
Based on this, I think I’m at the limit of what the DA can do and need a more powerful tool. Recently, I came across a used Dewalt DW849 for a great price. I’ve been reading everything I can find on how to use the rotary. I have a hood, fender, and plastic/rubber bumper cover from a body shop that I plan to practice on. I’m almost ready to go. Now the questions.
1. I want to stay with the 6.5” pads I already have so which rotary backing plate should I get? I know the W64 6.5” backing plate will work but will the W66 Solo or W65 8” also work with the 6.5” pads? I’m leaning towards the W66, but am not sure.
2. I do not currently have any cutting pads. Should I get some? Wool or foam or both? Which is more aggressive - wool or foam? I saw a post by Tim Lingor where he showed the aggressiveness of the wool pads as follows:
Most aggressive to least:
W5000 Double Sided
So1o Heavy Cut Wool (Red)
W4000
So1o Light Cut Wool (Yellow)
I’m leaning towards the W4000 wool pad and maybe a W7006 foam pad.
3. Besides the Explorer, I also own a Teal Green 1996 F350 and a silver 1995 Mustang. All are daily drivers with “normal” paint defects. What products, besides the D151, should I get to start with? It almost seems like M105 and M205 are the new M80 and M83. How similar are D151 and M205? Meaning could I finish M105 with D151? I think given the way the Explorer responded to the D151 on the DA my next step would be to put the same W8006 pad on the rotary and continue with the D151. Should I get some M105?
4. When will the “How to use the Rotary” DVD be coming out?
Thanks for all your help,
Shawn
W5000 Double Sided
W4000
Shawn
