Snow Foam
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Snow Foam
    Apr 2007
    US
    1,121
    26
    Snow Foam
    Was in the UK few days ago, and we saw a fellow washing his car with something called Snow Foam. You just put this stuff in a Pressure washer soap dispenser, add water, and spray the car on low pressure. It foams up, just like snow, and you let it sit for a few minutes, and then spray off. It did a great touchless job, apparently does not strip wax, but leaves a white mess on the ground after. It does eventually go away. Again, it did a nice job.
    Anything like that here in the US?
    Thanks,
    D.
    Fire Dept. Detailer Carfire's Avatar
    Aug 2008
    Ozaukee County ,Wisconsin
    29
    2,837
    43
    Re: Snow Foam
    Yes there are several different brands.
    Gilmour Foamster is for regular hose at your house. (2 different links)
    Karcher Foam Gun for Pressure Washers. (I believe)
    Apr 2007
    US
    1,121
    26
    Re: Snow Foam
    Thanks Carfire. I was looking for the product, and not the tool foamer. Got the foam gun, but not the foam. That looks like the stuff:http://www.youtube.com/watch?v=e4gsM6718P8
    but it seemed to be much thicker in the UK.
    Registered Member Tom Weed's Avatar
    Nov 2004
    1,107
    28
    Re: Snow Foam
    I haven't used the Snow Foam, but have used the Karcher foam gun with NXT, Gold Class, Hyper Wash and APC. It did make a nice thick foam, but if the car is dirty, you are still going to need to wash it, the foam however did losen up the winter crud on the car. I would say if it's just dusty you would be okay to spray and rinse. One thing, on dark colored vehicles, foaming when it's warm outside, the foam dries quickly, thus causing spotting.
    Aug 2008
    29
    2,837
    43
    Re: Snow Foam
    You can change the dilution on the foamer to have more or less foam/be more or less watery and stick more or less.
    The foam is actually just car soap.
    In the Gilmour you pour in your soap solution, in this case lets say Hyper Wash, and then you turn on the water and it foams.
    60
    24,759
    520
    Re: Snow Foam
    This is the feature everyone wants in a car wash as it just makes good sense, clean the car without removing the last coat of wax or paint sealant you applied.
    The trick is finding balance between strong enough to dissolve dirt and road grime without also effecting the last applied coating of wax or paint sealant.
    The problem is anytime something is strong enough to remove dirt and road grime without having to physically touch the paint then it's usually strong enough to also effect whatever coating was applied.
    Obsessive Compulsive Detailer eyezack87's Avatar
    Apr 2008
    Rancho Santa Margarita
    270
    17
    Re: Snow Foam
    From what I've read on various UK detailing forums, its a soap sold specifically over there. I haven't really researched it lately but I have noticed that some people do post the differences in the Karcher Foam attachment (not putting Cannon for this one) and the real Foam Cannon sold by Autobrite in the UK. I've read that the Foam Cannon blows the Karcher version out of the water but it is very similar to the Cam Spray foamer so that is an alternative that you can easily get here in the states.
    I've done almost everyone of my soaps in my Autobrite Foam Cannon and each one works equally well with the foaming. In terms of stripping LSP, however, that remains to be seen as I just received it last week (been having fun ever since! lol). It does do quick work of the car though
    If you want the real version of the Foam Cannon, ebay "foam cannon" and you will find a guy. He is the person I bought mine from
    Apr 2007
    US
    1,121
    26
    Re: Snow Foam
    Quote Originally Posted by eyezack87 View Post
    Thanks for that. I will have a look at eBay. I assume Gold Class wash will work with this.
    Thanks everyone else for your help.
    D
    Apr 2008
    270
    17
    Re: Snow Foam
    I have
    -Gold Class
    -Hyperwash
    -DP Autobath
    -DP Foam
    -Dawn
    -CG citruswashclear
    -some others
    Each one works very well. The only thing I noticed is that Dawn takes like 5 hours to completely dissolve on the ground but its still a lot of fun
    Apr 2007
    US
    1,121
    26
    Re: Snow Foam
    I searched for foam cannon and got lots of hits for foam seats, foam this and that, and found some real nice Cannon cameras...but no foam cannon. Checked all categories including eBay motors...no luck. Autobrite was a no hit also. Maybe this fellow is out of stock.
    Appreciate the help though.
    D
  1. Snow foam gone wild!
    By Tom Weed in forum The Break Room
    Last Post: Jan 28th, 2009, 04:48 PM
  2. Here comes then snow
    By JG_Detailing in forum The Break Room
    Last Post: Jan 28th, 2007, 11:08 AM
  3. Snow
    By Paramedic in forum The Break Room
    Last Post: Oct 15th, 2006, 06:16 AM
  4. FS: Foam Gun w/DP Xtreme Foam Formula
    By mshu7 in forum For Sale or Trade
    Last Post: Sep 28th, 2006, 12:45 PM
  5. snow
    By refurbish in forum Detailing 101
    Last Post: Sep 27th, 2005, 05:10 PM
