Ultimate Compound vs M105
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Ultimate Compound vs M105
    Nov 2008
    Seattle
    12
    Hi, I am thinking to buy Ultimate Compound or M105; however, I don't know which one is much stronger,and how much different?
    thanks
    Registered Member yalerd's Avatar
    Jan 2006
    4,439
    121
    Re: Ultimate Compound vs M105
    M105 is much stronger.
    Ultimate Compound I think is comparable to M83 in aggressiveness
    Car Guy In Training Mikejl's Avatar
    Aug 2008
    Lake Forest, CA
    1,316
    32
    According to the Aggressiveness Order I would think SwirlX is closer to 83 than Ulitimate Compound. From personal experience I would say that UC is closer to M105 than it is to M83 or maybe right between 105 and 83. (This is my own opinion and not Meguiar's).
    Mike
    George Carlin
    Registered Member ColonelCash's Avatar
    Feb 2006
    Nashville, TN
    1,337
    72
    Ultimate Compound is a little stronger than M83, which is about 6 out of 12 on the cutting scale. M105 is a 12 out of 12 on the cutting scale. I asked the same question a few days and got plenty of replies. Check the Ultimate Compound review thread started by Michael Stoops.
    Hatch Show Print Gallery
    59
    24,767
    519
    Quote Originally Posted by garychen0919 View Post
    thanks
    Time to start a new, dedicated thread just for the answer to this question
    Posted yesterday to page 2 of this thread,
    Ultimate Compound - Who's used it, what do you think?
    Question
    Quote Originally Posted by ColonelCash View Post
    Can anyone discuss the cut of Ultimate Compound to the new DA-approved M105? I'm not looking for chemical design, just a simple answer. Which one has more cut?
    Answer
    M105 is more aggressive than Ultimate Compound.
    M105 is in our Professional Line and primarily formulated and targeted at people using rotary buffers to remove sanding marks out of fresh paint in body shops. (Generally speaking, people in this industry have a high skill level for working with paint care products as they do this for a living).
    Ultimate Compound is in our Consumer Line and primarily formulated and targeted at people using a DA Polisher or working by hand to restore a neglected finish on factory paint. (Generally speaking, in the Consumer market, the average person washes and waxes their car 2-4 times a year. Online enthusiasts that hang out on discussion forums and work on their car more often don't fall directly into this category as they know more and tend to have a higher skill level for working with paint care products).
    And just to note, this subject has been brought up and discussed in one of these two threads,
    Ultimate Compound
    M105 Ultra-Cut Compound - New Formula DA Polisher Approved
    Maybe someone can read through the two threads and their multiple pages and verify?
    When you get to this level of aggressiveness, unless you're working with a rotary buffer both products are going to get the job done equally well.
    When working with a DA Polisher and ESPECIALLY by hand, your TECHNIQUE is more important than whether you're using M105 or UC
    So the questions are,
    • What are you working on?
    • What is the goal?
    • How are you applying the products?
    Nov 2010
    Palm Springs
    4
    Well, I would consider that immaterial......if the technique you are using doesn't change from product to product.
    I'm relatively new to all this, but I have tried a number of these products.
    Currently using Ultimate Compound with a rotary, and I must say it takes a LONG time to get out moderate to light scratches/swirl marks.
    Tried SwirlX first, and same deal.
    Don't get me wrong.....the tiny tiny swirl marks ARE removed....but the ones that take a LONG time aren't that deep in my view....
    I think all these are made to be 'safe' so the average user doesn't mess up his paint job.
    And another observation.....all these products do the same thing....but they all have such catchy names.......I think this is all a marketing ploy.
    Gonna try the 105 when I can figure out where I can buy it.....
    ALL these products should have a bar chart like the 105 does, that would let a person know what the agressiveness is...........I'm thinking these products are used by a lot of people that really are willing to spend quite a bit of money for quality..........so I suggest some type of indication as to what the products do from a comparison standpoint.....otherwise, it's just hype what you read on the label.............z
    Nov 2010
    Palm Springs
    4
    PS. Just noticed that the last 2 also have a bar chart, so it's the middle 3 that need an agressiveness indicator.........z
    Mr. greg0303's Avatar
    Nov 2009
    Brooklyn New York
    2,888
    66
    Zardiw, did I get it right? You said that you used Ultimate Compound with rotary buffer? It's not formulated for that. UC should be strictly used with dual action polishers and hand applications. No wonder it took extremely long time to correct those defects.
    If you primarily work with rotary buffer M105 is the right compound. You can easily remove serious defects including 1200 grit sanding marks. However M105 dries pretty quickly and therefore it has pretty short buffing times. But its cutting ability is powerful.
    If you plan to work with DA polisher you could use both compounds (just make sure you get DA approved version of M105). As Mike said, working with random orbit machine and having good technique would enable you to get almost identical results with both products: M105 and UC. UC would extend your buffing times.
    Jul 2006
    Orange County, CA
    36
    4,138
    145
    Quote Originally Posted by Zardiw View Post
    The reason being the products are from different lines and use different technologies and application methods. They were never intended to be compared, but the chart was created to provide a rough idea of cut levels.
    Nov 2010
    Palm Springs
    4
    Yes. I can't get 105 at my local industrial supply store. And I'm assuming that UC breaks down too fast in a rotary.....tried it by hand and it seems to work good........Bought some 3M Ultra Compound.......that should do the trick........Tired of screwing around......z
  1. Ultimate Compound
    By Mike Phillips in forum Meguiar's Product Introduction Threads
    Last Post: Jul 6th, 2010, 08:24 AM
  2. Ultimate Compound - Who's used it, what do you think?
    By Michael Stoops in forum Meguiar's Consumer Line Products
    Last Post: Mar 1st, 2010, 10:45 AM
  3. M105 Ultra Cut Compound - New!
    Last Post: Sep 6th, 2009, 12:47 AM
  4. Quick M105 Ultra Cut Compound Questions
    By Chex in forum Detailing 101
    Last Post: Jun 28th, 2008, 08:06 AM
  5. M105 Ultra-Cut Compound Kit - New
    Last Post: Mar 27th, 2008, 12:25 AM
