water spot remover
Results 1 to 3 of 3
Thread: water spot remover
    Registered Member DSG Man's Avatar
    Jul 2004
    97
    16
    water spot remover
    Eraser (Water Spot Remover) 1 Gallon (#105G01W)
    Removes scum and hard water spots from glass and body of the car with very little effort. It will restore the optical clarity of the glass. This mild acid based formula will break the bond between mineral deposits and the surface. Amazingly will remove water spots from painted surfaces, thus preventing heavy duty buffing. Excellent on car wash tunnel windows and shower doors.
    Anyone ever try this stuff to remove water spots on cars?
    Attached Images Attached Images
    59
    24,767
    519
    Hi DSG man,
    I've never tried this product before, I have to wonder if it's dangerous to both myself, (skin contamination, ventilation, etc.), or my paint should I get some on it.
    For years what I've used for heavy water spots on glass is #4 Heavy Cut Cleaner.
    M-04 Heavy Cut Cleaner
    This is a product formulated for use with a rotary buffer only when used on automotive paints. It contains a fairly aggressive diminishing abrasive that can easily be felt between your fingers. It is this larger diminishing abrasive that when applied with a piece of terry cloth towel, which enables you to cut through any film that has built up on glass, or water spots that have built up on glass without scratching the glass.
    In Oregon and Washington, I often came across cars that I was detailing that had heavy accumulation of water spotting and/or some kind of chemical contamination build-up on the exterior glass. It didn't do any good to polish the paint on the car only to have the glass looking all dull and shabby, so I would always polish out the glass and found the either the #4 Heavy Cut Cleaner, or even the #1 Medium Cut Cleaner to be quite effective at removing water spots and other contaminants while leaving the glass highly polished and smooth as new glass again.
    Mike
    Jul 2004
    97
    16
    I'll have to double check, but I believe I heard about it on Autopia.
  1. marine line Water spot remover
    By Chex in forum Detailing 101
    Last Post: Oct 6th, 2006, 07:10 AM
  2. Would Meguiar's Hard Water Spot Remover.....
    By EkS in forum Detailing 101
    Last Post: Aug 30th, 2006, 07:49 AM
  3. #47 Hard Water Spot Remover
    By fgraciano1980 in forum For Sale or Trade
    Last Post: Jan 24th, 2006, 05:49 PM
  4. Hard Water Spot Remover
    By RedSoxRacer in forum Detailing 101
    Last Post: Jul 27th, 2005, 04:01 PM
  5. Water Spot Remover
    By Rockpick in forum New Product Suggestions
    Last Post: May 9th, 2005, 03:29 PM
