I would like to know the difference in the professional line and consumer line cleaner wax products. Also, are these all in one cleaner waxes as effective as using the deep crystal 3 part system? Thanks
pro line/consumer line differences
Re: pro line/consumer line differences
Well depending on the product there are some that are the very same just in different packaging for the different markets. The pro line is more geared toward the detailers as it offers more of the product in a higher quantity. There are a lot of the pro line that aren't offered in the consumer due to the abrasive qualities and the application process.
For the all in one cleaner/wax combos there is one that I know of called D151 which to my understanding is a great product and I will be getting some very soon. Now, I'm not sure but, I think this is a product that is mainly used with a rotary or a DA.
Depending on what your goals are and what your working with will tell what you actually need to use. When I first started I used the DC system until I understood the basics then I researched and researched and researched all the products and the abilities of them along with how to apply and work them.
I hope that helps you out a little bit
Certainly the bulk size is a big difference, but the Consumer Line is also mostly geared for the average user working by hand.
#6, #66, and D151 are all cleaner/waxes.
The DC products are mild, esp the paint cleaner. So compared with a mild cleaner/wax, then yes, the DC system would tend to give better resutls. Now if you have swirls to remove, then a stronger/cleaner wax may remove the swirls better than the mild cleaner.2017 Subaru WRX Premium - WR Blue
Originally posted by hobby11 View PostI would like to know the difference in the professional line and consumer line cleaner wax products. Also, are these all in one cleaner waxes as effective as using the deep crystal 3 part system? Thanks
There are two cleaner/waxes in the Consumer Line
A12 Meguiar's Cleaner/Wax
ColorX
There are 4 cleaner/waxes in the Professional Line
M20 Polymer Sealant
M06 Cleaner/Wax
M66 Quik Detailer
D151 Paint Reconditioning Creme
In order of aggressiveness from least to most aggressive,
M20 Polymer Sealant
ColorX
M06 Cleaner/Wax
M66 Quik Detailer
ColorX, M06 and M66 are actually all pretty close, M06 and M66 can be applied with a rotary buffer, that means they're formulated to perform when heat is a factor.
What are you working on?
What are you trying to accomplish?
Originally posted by thoryamaha919 View PostWell depending on the product there are some that are the very same just in different packaging for the different markets.
Originally posted by thoryamaha919 View PostThe pro line is more geared toward the detailers as it offers more of the product in a higher quantity.
Originally posted by thoryamaha919 View PostThere are a lot of the pro line that aren't offered in the consumer due to the abrasive qualities and the application process.
Since you're in SoCal, you might want to attend one of our classes, all you have to do is reply to the appropriate sign-up thread for the class you want to attend.
Saturday Classes for 2009
All Saturday Classes are Open Classes, any Registered Member can attend by signing up for a class by replying to the sign-up thread.
2009 Saturday Class ScheduleMarchThursday Night "Open Classes" for 2009
March 7th - Open Class
March 21st - Advanced Class #5
April
April 4th - Open Class
April 25th - Open Class - "Ladies Only"
How to get your Car Club scheduled for a Saturday Class at Meguiar's
If a car club wants to attend a Saturday class, then each member needs to get signed up before the class fills up with our regular forum members. Membership on our forum is free, click here to register and then reply to the sign-up thread for the Saturday Class you want to attend.
2009 Thursday Night "Open Garage" ScheduleMarch
March 19th - First Thursday Night "Open Garage" - Click here to sign-up
(Daylight Savings Time kicks in on March 14th)
This first class will also be an extreme makeover class as we remove the swirls and
create a show car finish on this 1954 Oldsmobile Rocket 88 Convertible.
April
April 2nd - Thursday Night "Open Class" - Click here to sign-up
April 16th - Thursday Night "Open Class" - Click here to sign-up
