Water Spot removal
Results 1 to 2 of 2
Thread: Water Spot removal
    Mar 2009
    Kona, Hawaii
    4
    Water Spot removal
    Hey, this is my first time posting after reading for about 2 weeks now, I have learned a lot. I am currently trying to restore a decent finish on a Black 94 Acura Integra. It is my brothers old car which he so nicely killed the finish for me. It was parked for a while on the street so it has water spot galore on the windows and paint. I am currently going to do everything by hand and have picked up some Ultimate Compound and Swirlx. I have a couple questions, one would be what other products and steps should I use to remove minor scratches and heavy water spots. Also I was wondering if I could use a different product other than M04 to remove water spots on windows by HAND, could I use UC or SwirlX? Thanks a lot for any future help and I am looking forward at the project I have ahead of me
    57
    24,779
    517
    Re: Water Spot removal
    Quote Originally Posted by dude808 View Post
    I am currently going to do everything by hand and have picked up some Ultimate Compound and SwirlX.
    Ultimate Compound is our most aggressive product in our Consumer Line, when working by hand, if this product isn't aggressive enough to get the job done it's more than likely the defect is too deep or serious to safely be removed by more aggressive means and it might be time to learn to live with the defects and/or looking into more advanced techniques for defect removal.
    Just as important as using the right product is using the right technique, for example when using UC by hand to remove below surface defects you want to lonely work on a small section at at time, that would be approximately anywhere from an 8" square are to a 16" square area depending upon how hard the paint is, how deep the defects are and your skills and abilities to work paint by hand.
    You certainly can't tackle half the hood at one time and that's because removing defects mean removing paint as explained here,
    Also, before applying ANY product over the entire car, dial-in your system by doing a Test Spot.
    TEST SPOT
    Doing A Test-Spot
    Before going over the entire car, see if you can make just one small section look good, that is apply the product you're planning on using over the entire car to just one small section about a foot squared or so. Work it in and then wipe it off, then apply the polish, work it in but not as much as the compound because now you're not trying to remove paint, just spread the product out, then immediately wipe it off, then apply the wax and let it fully dry and then wipe it off.
    Now inspect our results. Make sure you can make one small section look GREAT before going over then entire car. If you can't make one small section look GREAT you won't be able to make the entire car look GREAT.
    Make sense?
    It should look like this,
    M04 works because of the large, chunky diminishing abrasive used in this particular formula. UC uses our new Super Micro Abrasive Technology and it's a completely different type of animal.
    I just went out and tried Ultimate Compound on some mineral deposit water spots on the glass of my truck with a foam applicator pad and it worked just fine to remove these spots and restore a very smooth, clear surface to the glass so give it a try on your car's glass and remember to put a little passion behind the pad if there's a lot of built up gunk and contaminants on the glass.
  1. Water Spot/Etching Removal and Trim Detail (by Hand)
    By volvie! in forum Show Off Your Latest Detail Work
    Last Post: Jan 15th, 2009, 03:43 PM
  2. spot scratch removal
    By tomee in forum Show Off Your Latest Detail Work
    Last Post: Mar 19th, 2006, 04:44 PM
  3. Water Spot Removal - the next step?
    By davisinla in forum Detailing 101
    Last Post: Jan 26th, 2006, 07:59 AM
  4. Water Spot Removal
    By 305Cummins in forum Detailing 101
    Last Post: Jun 27th, 2005, 05:52 PM
  5. Water Spot Help!
    By Tanat198 in forum Detailing 101
    Last Post: May 4th, 2005, 07:57 AM
