Pictures & Comments for Advanced Class #5 - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Pictures & Comments for Advanced Class #5
  1. #11
    Director of Global Training, Events & Consumer Relations Mike Pennington's Avatar
    1,706
    37
    Re: Advanced Class #5 - 3.21.09
    Quote Originally Posted by termigator69 View Post
    Does the rule of not wetsanding factory paints apply to single stage paints also?
    On vehicles with factory paint you are still dealing with approximately the same topcoat thickness even with a single stage style of coating.
    So it is a good rule of thumb to follow the same general rules....
    Mike
    Just a reminder: When we say it is not a good idea to sand, we are saying it is not a good idea to sand for the purposes of removing orange peel....However, sanding with the appropriate grit in order to remove an isolated defect would be ok regardless of finish on a factory car as long as you are monitoring the amount of material you are removing.
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
  2. #12
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Jan 2009
    San Diego, CA
    2,310
    62
    Quote Originally Posted by Mike Pennington View Post
    3) We limit how much sanding is done and with what grit we allow class members to use. We only remove .2 - .4 mils which is well within the specs of OEM factory repair.
    Even did the before and after with the QuaNix meter. Only removed about .2 mil overall if I remember correctly.
  3. #13
    21,405
    1140
    Hold on tight, there's a ton of pictures in this post!!!
    This is what we started with -
    Mike Pennington added a little more to the existing mess.....
    A little wet sanding by hand........
    Wet sanding by hand the right way.....
    .....and the wrong way.
    Wet sanding with a D/A.....
    Very nice!!
    Cleaning the wool pad.......
    How to pick up a bead of product.....
    Pulling out sanding marks......
    Oh come on, he didn't actually miss a spot, did he???
    Ah... no. Mike's a bit picky, eh?
    And then we turned everybody loose on the rental car!!
  1. Advanced Class #2 - Pictures & Comments
    By Mike Phillips in forum Pictures from Meguiar's Training Garage - Intro to Wet Sanding & Rotary Polishing Classes
    Last Post: May 28th, 2008, 02:12 PM
  2. Advanced Class #1 - Pictures & Comments
    Last Post: Apr 19th, 2008, 06:36 AM
