Used swirlX for the first time
  • Used swirlX for the first time
    Over the weekend I picked up a bottle of swirlX and decided to try it out.
    I have a question about my results.
    I own a black car, and as we all know, black cars are known for their swirls.
    Here is what I started out with..
    Here is what i started out with after a basic wash.
    I then applied the swirlx with a terry pad, working each section in at a time until I felt the product begin to dry up.
    Then after initial wipe down, I took a picture and saw this...
    Looks terrible right? I got a little worried at this point, but started thinking that perhaps all these swirls were not really new damage, but just left over product that didn't fully get removed when I wiped the car down.
    So I decided to wax the hood with tech wax, to see if the wax would remove the rest of the product that was left over. I took another pic, and right away the problem seemed to have been fixed.
    So my question is, am I right to assume that the extra swirls I was seeing was just left over product, or did the swirlX damage my clear coat in any way, and the wax is just concealing it?
    In case you are wondering, the whole car came out great. Assuming that swirlX didn't add any new swirls, I'm actually really happy with the difference it made in my car.
    Here are some real world shots without the flash.
    Re: Used swirlX for the first time
    Comparing your first and second pic, not much seems to have changed? That is to say, the SwirlX didnt damage anything, but may not have been strong enough/worked with enough passion to remove the swirls that were there?
    Nxt 2.0 is pretty good at covering things up.
      Hard to tell from the pictures but usually when you correctly apply a swirl and scratch remover you'll remove the most shallow swirls and scratches first and what this does is makes the deeper swirls and scratches show up more easily to your eyes, it more or less makes the the deeper swirls and scratches that were already there stand out like a sore thumb because now there are less swirls overall to cloud or camouflage the deeper ones.
      Looks better and looks normal to me. Also looks like you might want to try ScratchX 2.0 or Ultimate Compound.
        Sorry guys. I placed the wrong link for the second picture.
        This is how it really looked after the swrilX
          Can a product like Ultimate Compound work by had if applie with enough "passion"???
            This is how it really looked after the SwirlX
            I then applied the SwirlX with a terry pad, working each section in at a time until I felt the product begin to dry up.
            The first goal of a paint cleaner or in this case a cleaner/polish is to remove a little paint so it will level the surface and thus remove the below surface defects. The second goal is to do this in such as way as to not simply replace one set of defects with a new set of defects and the next goal is to hopefully leave as nice of looking finish as technology in partnership with human skill level will allow.
            A couple of questions?
            How big of an area did you work at at time?
            When you say terry pad, do you mean like one of the round terry cloth applicator pads you can buy at most auto parts stores?
            Using good technique with a foam applicator pad you should be able to apply and work the SwirlX to a small area and leave a fairly nice finish although remember the paint cleaner isn't the last step in a multiple step process.
            For right now, try this,
            After washing or wiping the car clean, apply about a teaspoon of SwirlX using a clean foam applicator pad to a section about 8" to 12" square.
            Spread the product out over the area using a overlapping circular to spread it out over the area.
            The idea being before your start working the product first spread it out and create a uniform layer of the SwirlX over the area you're going to work.
            Now apply some medium pressure and work the section for about a minute. Note that you should never work until the paints starts looking dry, there should always be a wet film when you're working a pad over the surface. If you move a pad over the paint after you've lost lubrication you can marr the paint.
            Wipe off this wet film carefully with a clean, soft dry microfiber, the results should look good, as in hopefully less swirls and scratches, (anything that's not very deep), and the paint should be clear and glossy, sometimes like you just waxed it but technique is the key to creating a clear, glossy appearance when working by hand.
            The next step would be to move on to new territory and work a new section and be sure to overlap into the previous section for good UMR, Uniform Material Removal for a uniform appearance.
            You would repeat this until you work over the entire panel or over the entire car.
            After this you could polish as an optional step with a pure polish or skip right to the wax or paint sealant.
              Hi Mike,
              After spreading out the product, can we work the section in straight motion or do we continue in circular motion?
              I know that for ScratchX we can go either circular or straight.
                I might add that it looks like there are some straight motion finger marks as well. This would be from too much concentrated pressure on your finger tips.
                Were you pushing hard and rubbing straight forward and backward at some point?
                  This is pretty much exactly what i did. I used a terry applicator pad with a handle on it. What would be the difference between using a terry pad and a foam one?
                  I worked each area until I felt the product dry up. By this I mean, that I stopped as soon as I felt that the product was no longer moving smoothly. This is probably around a 1min working time on each section.
                  My question is this...
                  Is my theory correct that the only reason the pic after swirlX looks worse, is because there is still some swirlx residue left over that was not fully removed when wiping down? If you look closely, it almost looks like there are large streaks and not scratches in the paint.
                  Once I applied/removed a layer of wax, this was magically corrected. Its kind of hard to believe that wax was able to just cover up what looks to be like a lot of damage. My theory was that once the wax dried, it made it a lot easier to remove the swirlx that was streaked into the paint.
                  Not possible for there to be any excess finger tip pressure. I used a terry applicator pad that has a velcro handle attached to it. This gave me about as a uniform application as possible.
                  I may have used some straight motions, but I believe I read on this forum that the direction of your application should not matter with this product.
                    You could be 100% right, and like I said, I thought it *might* be (hard to tell from a single stationary picture without being able to change my viewing angle and see how the light reacts to the paint).
                    I highlighted the areas of concern to me. If they move around as you move your viewing angle under the light, they may just be light trails and nothing from your fingers.
                      Foam is more gentle to automotive paints the cotton terry cloth which has a fiber nap.
                      Sounds like you rubbed too long... there should always be a liquid/wet film on the surface, not dry paint.
                      Was in Florida last Sunday and in front of over 35 people I applied SwirlX and Ultimate Compound using a foam applicator pad using the technique I outlined above and all the eyeballs there saw clear, glossy paint after wiping the residue off.
                      Pictures and comments from Meguiar's Roadshow Class at Autogeek's Detail Fest 2009
                      We always go over the basics including the correct way to hold an applicator pad and why...
                      First we tested the polishability of the paint by using the least aggressive product in our demo, SwirlX
                      First we spread the product out over the area we're going to work and then we start working the
                      product over the paint putting some passion behind the pad...
                      Checking our results after one application; while SwirlX did a great job there were still traces of the
                      deeper swirls, scratches and water drop etchings in the paint so we decided to test out Ultimate Compound.
                      So it can be done. Applying any thing that abrades the paint means using GREAT technique and the right application material.
                      Try again, get some soft, foam applicator pads and work a small section and stop before you work to a dry buff.
                      Polishing paint is an art form, not merely a mechanical process, it requires the right tools and products but also the human elements of care and passion.
                        For anyone reading this that is new to polishing on clear coat paints, one of the things we do on this forum is teach and preach the importance of doing a Test Spot first.
                        Make sure your products of choice, together with your skills and abilities can make one small section look great BEFORE going over the entire car.
                        If you can't make one small section look great with your process then we'll help you to tweak your technique until you can make a small section look great and then you can tackle the entire car.
                        TEST SPOT
                        Doing A Test-Spot
                        Before going over the entire car, see if you can make just one small section look good, that is apply the product you're planning on using over the entire car to just one small section about a foot squared or so. Work it in and then wipe it off, then apply the polish, work it in but not as much as the compound because now you're not trying to remove paint, just spread the product out, then immediately wipe it off, then apply the wax and let it fully dry and then wipe it off.
                        Now inspect our results. Make sure you can make one small section look GREAT before going over then entire car. If you can't make one small section look GREAT you won't be able to make the entire car look GREAT.
                        Make sense?
                        It should look like this,
                        And if you're having any problems, the post back here after the test section and we'll help you tweak your technique to insure you get it right.
                          Also remember a paint cleaner isn't the same thing as a finishing wax and you won't get the same visual results when viewed under BRIGHT LIGHTS.
                          The hope is that if you use one of our swirl and scratch removers by hand that the paint WILL look great after using it but again, each person's end results is heavily influenced by the persons skill and ability.
                          The defect removal step is just one step in a process with the last step being the step the gives you your final end-results.
                            Mike and everyone else... Thanks for the help so far. It really is great to be able to directly talk to the people who represent these products. It means a lot as a customer.
                            However I still have this question. If what I was seeing was "damage" to the paint after using swirlx, would the tech wax be able to simply hide all that after one application?
                            Right now when I look at the car in direct sunlight, i dont see any of the "damage" that I saw right after applying the swirlx.
                            What should I do if I want to try another pass with the swirlX? I already waxed the car, so can I simply wash/dry it as normal, and apply the swirlX, or do I need to do anything to special to prep the surface since its just been waxed.
                              bump?
