A look into Pad Priming - The Kevin Brown Method - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 57
Thread: A look into Pad Priming - The Kevin Brown Method
  1. #11
    Aug 2008
    Harrisburg SD
    194
    14
    Re: A look into Pad Priming
    Quote Originally Posted by BlueZero View Post
    Great info Chris! Thanks for posting it here!
    What do you use to spread and rub the product in? First thought would be your hand but I'm wondering if there isn't a less messy option that works as well.
    I was wondering the same thing
    ______________________
    Tyler
    2002 Yellow Chevy Monte Carlo SS
    My Albums: http://s394.photobucket.com/albums/pp24/Johnson0667/
  2. #12
    Person PorscheGuy997's Avatar
    Apr 2006
    Southern Indiana
    1,344
    35
    I just prime the pads with a finger. Usually, I just apply a circle of the polish, work it into the pad, and then apply a bit more polish to the dry areas and work it in.
    You might be able to prime it using a pen or something, but I haven't tried anything else.
    Chris
    Dasher Detailing Services
  3. #13
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,314
    50
    I've thought about the application since then. I wonder if a putty knife wouldn't work good. The plastic ones are pretty cheap.
    Scott
  4. #14
    Apr 2006
    Southern Indiana
    1,344
    35
    Yeah, a putty knife might work.
    My only concern would be that the knife could cut into the pad. You need something that can be pressed into the pad to work the product in.
    I normally prime the pad before polishing. Then, I just add the product when needed. The priming is not after each section, but rather when the pad is fresh and devoid of product.
    Chris
  5. #15
    Registered Nappers Nappers's Avatar
    Aug 2006
    Yreka, CA
    51
    3,551
    187
    Is this for DA or Rotary use? Or both?
    Looks good.
  6. #16
    Apr 2006
    Southern Indiana
    1,344
    35
    Pad priming can be used on all machines: DA, rotary, and Cyclo.
    Kevin's paper will only cover the DA, though.
    Chris
  7. #17
    Aug 2006
    Green Bay, WI
    3,314
    50
    Thanks Chris! I'm looking forward to give this a try. Hopefully soon.
    Scott
  8. #18
    Registered Member Still Learnin's Avatar
    Feb 2009
    Rancho Cucamonga
    405
    16
    this is a great thread. my yellow foam pad was dusting when i was polishing... learned thsat i had a few dry spots on the pad and when it slightly tilt the g110 it would dust like as if i was shaving the pad. primed it will a little of 205 or whatever polish ill be using and viola... no more problems...
  9. #19
    Registered Member wyseilmykkar's Avatar
    May 2006
    Ontario Canada
    181
    16
    If you've ever painted a room/surface with a roller you already now how to prime a pad; if you don't get the entire surface of the roller covered with paint when you start on your surface you're going to have voids where the roll is dry. You don't want to load the roller to the point where you can't move it from over the pan for fear of dripping, but rather an even amount. Same principle applies here, IMO.
  10. #20
    Apr 2006
    Southern Indiana
    1,344
    35
    Very true.
    I would like to add that this method is NOT for use with products that use diminishing abrasives. If you use a product that uses abrasives that break down, there might be some inconsistent polishing because the abrasives break down randomly.
    Chris
  1. Priming a Pad
    By sudsbyhubbs in forum Detailing 101
    Last Post: Nov 25th, 2008, 02:49 PM
  2. Priming a new/dry foam pad.
    By premier.mobile1 in forum Detailing 101
    Last Post: May 28th, 2008, 11:42 AM
  3. Priming New/Clean Pad
    By zey in forum Detailing 101
    Last Post: Jul 18th, 2005, 04:08 PM
  4. Priming pad for NXT w/Booster?
    By Don in forum Meguiar's Consumer Line Products
    Last Post: Oct 5th, 2004, 11:51 AM
  5. Priming Foam Pads
    By screemingtp in forum Meguiar's Professional Lines - Mirror Glaze & Detailer
    Last Post: Mar 11th, 2004, 10:45 AM
Tags for this Thread
