How is it that some of you guys who are pros detail using ONR or other waterless car washes without getting fined for waste water? Doesn't ONR still drip water onto the ground. I thought that if the water gets on the ground, it violates California's laws on the issue?
Mobile Detail with ONR
Re: Mobile Detail with ONR
Originally posted by andrewc_11890 View PostHow is it that some of you guys who are pros detail using ONR or other waterless car washes without getting fined for waste water? Doesn't ONR still drip water onto the ground. I thought that if the water gets on the ground, it violates California's laws on the issue?
Only "Rain in the Drain" is the motto of most coastal cities. ONR doesn't runoff to the drains, does it. So it wouldn't/shouldn't get you a fine. It has a very neutral PH reading, so it can be dumped into the ground after using it.
If your doing the conventional washing of your vehicle or are a mobile detailer, know your water containment rules for your city! Fines are getting higher and higher!
Water conservation is very important right now for all of California.
ONR is great product for these times of water shortages. I would still use it, even if we had an abundant supply of water in California.
well the laws in california differ between cities, like where i live, the code is usually only enforced in the summer. and all it really says is that if you are washing your car at home from your hose, it must be within a reasonable time limit and the hose must also have a nozzle that allows the water to stop flowing when not in use.
Im no pro or anything, but i still use ONR just because it uses a whole lot less water, still gets the job dont just as good, if not better. and its just doing my little part to try and conserve as much water as possible out here in the desert.
Originally posted by TerryAdams View PostOnly "Rain in the Drain" is the motto of most coastal cities. ONR doesn't runoff to the drains, does it. So it wouldn't/shouldn't get you a fine. It has a very neutral PH reading, so it can be dumped into the ground after using it.
As long as it doesn't go in the drain your ok.
You can look at it this way, if you mix up 3 gallons of ONR (what I typically), at most 3 gallons will get on the ground. If you have a rinse bucket, you can add that as well or just dump in the sink. This can help determine what constitutes run off.Al
~ Providing biased opinions
I tried the no rinse products, and really didn't like them. There are things that you just can't do with an ONR product, or they are exremely hard to do. Like cleaning wheel wells, insides of wheels, engines, etc... If you're just taking care of the exterior paint on your vehicle, then ONR is a great product. But if you're trying to do a full deep cleaning, then I'll stick with my pressure washer. I can do an entire vehicle with about 10 gallons of water out of my van. So it's not too wasteful. A little more then ONR, but not real bad.
Right now, I'm working on a new idea for water(look for a thread here shortly). Going to collect rain water from my gutters
Nick2008 Meguiar's Batmobile Team
2008 Meguiar's/Ford SEMA Team
2009 Meguiar's/Ford SEMA Team
2010 Meguiar's/Ford SEMA Team
Originally posted by Nick Chapman View Post= There are things that you just can't do with an ONR product, or they are exremely hard to do. Like cleaning wheel wells, insides of wheels, engines, etc...
NickAl
wow, things seems complicated in the US, down here in indonesia, we dont have those laws, or maybe we do, but dont think anyone obeys them or any law enforcers understands them.....
but wouldn't it just be the same if ONR or any other liquid chemicals runs down the drain? it would still end up at a water refinery...Ganesa,
Toyota Vios '05
Originally posted by Ganesa View Postwow, things seems complicated in the US, down here in indonesia, we dont have those laws, or maybe we do, but dont think anyone obeys them or any law enforcers understands them.....
Where I live, anything that goes down the storm drains goes strait to the ocean with no processing in between, so that is why they have these laws in order to prevent pollution.
Remove swirls my friends.
