APC or APC+
  • APC or APC+
    What do you prefer and why? APC or APC+
    49
    APC
    32.65%
    16
    APC+
    67.35%
    33
    Remove swirls my friends.
    Re: APC or APC+
    I have APC so APC.
      Re: APC or APC+
      I have not used APC+ so I can't say
      AeroCleanse, LLC
      www.aerocleanse.com
        Re: APC or APC+
        I use them both, but for different purposes.
        APC is great for spot treatments when you are working with a hand-held brush.
        APC+ is the fantastic if you are using an extractor or DA carpet brush (my case). Plus, the orange scent is nice.
        If I had to choose one of the two, it would be APC+.
        Chris
        Dasher Detailing Services
          Re: APC or APC+
          I have APC, i have not tried APC Plus though.
            Re: APC or APC+
            APC+
            Like the smell better! I think it has less foam too.
            Both work well though.
              Re: APC or APC+
              My APC+ doesn't seem to smell like oranges .... I wonder why, it just doesn't really smell like much of anything.
                Re: APC or APC+
                APC+ here, just seems to be more versitile to me, plus it smells awesome
                I actually have both at the moment but have found myself using APC+ more often
                  Re: APC or APC+
                  When I purchased my APC, it was the replacement for the original APC+ of several years back.
                  Since I had been happy with the original APC+, the new APC seemed to be a logical choice.
                  Since I don't use an extractor, foam or no foam was of no concern to me. The scent was also of no interest to me. The APC certainly isn't objectionable to me at the 10:1 ratio I use.
                  When Meguiar's came out with the APC+ available today, I was under the impression that less foaming was the only real difference between it and APC.
                  After reading the comments of some of the Meguiar's people that they feel the APC+ is a slightly better cleaner, it appears that the APC+ might be the better choice when I need more.
                  That might be a while since 11 gallons of APC mix lasts a hobby detailer quite some time.
                  Charles
                  The Rainmaker
                    Re: APC or APC+
                    I have both, but must say I prefer APC.
                    I've read from the Megs people that APC+ is supposed to be a bit stronger, but I have found that APC works better for me. I like them both and I do prefer that "just clean" smell from the APC.
                      Re: APC or APC+
                      Can both be used on leather? If so what raito?
                        Re: APC or APC+
                        How does the DA carpet brush work for you? I can't afford an extractor right now and want to know if that will help.
                          Re: APC or APC+
                          I realy like them both. They both have a place. If I was forced to choose only one. I would pick the apc+.
                            Re: APC or APC+
                            It is a brush that screws on to your DA just like a backing plate. I just used mine a few weekends ago to clean up my mats and carpets and it made quick work of it. I just sprayed some cleaner on the section to be cleaned, grabbed my DA with the carpet brush attached, worked the brush over the area for a minute or two. Vacuumed as much cleaner off as I could and then rinsed with my Little Green Machine and used the LGM to vacuum the water up. Lastly I used my Stanely Blowers to dry the carpet for a few hours (probably only needed an hour but didn't want to risk mold/mildew). Did a fine job.
                            In a month or two my brother and I may tackle his miny van. My nieces and nephews have made a mess of it.
                              Re: APC or APC+
                              Thought this topic just came up recently?
