APC or APC+
  • #16
    Re: APC or APC+
    It did,
    Any reason to get APC over APC+
    APC vs. APC+ Let's hear it from Meguiars
    What to buy APC or APC+
    APC versus APC Plus
    Think any questions in this thread are already covered in one of the above threads...
    • #17
      Re: APC or APC+
      Thought this topic just came up recently?
      I feel certain we will probably see another before May is up.
      • #18
        Re: APC or APC+
        I have used both and I think APC+ is better for my uses. Seems to not foam up as much and leaves a nicer finish.
        Don't like the smell though.
        Ryan
        • #19
          Re: APC or APC+
          APC+, because it can actually be sprayed out of a spray bottle, unlike APC which foams so much, it's literally impossible to get it to come out.
          • #20
            Re: APC or APC+
            Interesting.
            At times I have even used APC with a foaming sprayer to get it to foam and cling to wheel wells. (Didn't work all that good)
            When used with a regular spray head, I have no problem whatsoever in spraying it on a surface. Actually, no foaming is even noticeable.
            I use it at 10:1 in most cases, but the few times I used it at 4:1, it didn't seem to foam a great deal either.
            The gallon I am using was purchased a few months after the original APC+ was discontinued and is probably a few years old. Maybe that is the difference.
            Charles
            The Rainmaker
            • #21
              Re: APC or APC+
              I use APC+. It's great for all-around cleaner (house and auto), and for carpet extraction as well.
              • #22
                Re: APC or APC+
                Day to day, APC+, simply because it smells better. Although I have a gallon of APC so I will sitll be using that as well.
                Dilution Chart
                • #23
                  Re: APC or APC+
                  Originally posted by drastic_detail View Post
                  can both be used on leather? If so what raito?
                  +1
                  • #24
                    Re: APC or APC+
                    Ive used APC+ on leather and have never had a problem. More specifically I will use it with a mr clean magic eraser and use the APC+ instead of water if it is really soiled leather. I use it at a ration of 10:1
