question on #50
  • question on #50
    can #50 Cleaner Wax be used with a DA?
    What am I, fly-paper for morons?
    Re: question on #50
    It sure can, if you have the paste, others scoop some out with a plastic butter knife/plastic spoon and put it on the pad, done it with NXT All Metal Polysh before, works great.
      Re: question on #50
      no, I have the liquid, not the paste.
      If the liquid version is not "approved" for DA use, what would be the downside of trying to apply it with a DA? Does it just dry up to dust too quickly?
        Re: question on #50
        Just to note, the liquid version is approved for use with a DA Polisher and works quite well this way. While we don't recommend using our foam cutting pads on CLEAR COAT Automotive paints, you can use them on oxidized gel-coats and the combination of M50 and a small foam cutting pad works really well to remove oxidation and leave behind a high shine, protected finish.
        Use the 5.0 Speed Setting and follow all the tips and techniques listed here,
        How To use: G110 - G220 - G100 - PC/Porter Cable - UDM
        If you're moving up to machine polishing, be sure to read the below thread before starting...
        Tips & Techniques for using the G110, G100, G220 and the PC Dual Action Polisher
        (These are all similar tools)
          Re: question on #50
          thanks Mike!
          Glad to hear that #50 is approved for use with a DA. The boat is a 27' Fountain speedboat so using a DA will be much quicker than having to do it by hand.
          I use a Flex 4301 DA and was thinking of trying a test spot using the #50 and a white CCS LC 6.5" pad and than seeing if I need to go up to an Orange pad or not. All depends on the condition I'll find when I see the boat next week
