I picked up my car from someone in NC 2.5 years ago. It's a Black 2002 Saab that looked perfect when I first bought it. I drove it up to NYC and it's been here ever since. I park it outside 24/7 and occasionally for the last two years it spend about 1 day each week parked under elevated train tracks. Ugh When it was washed, it was at the local car wash with harsh soaps. But now I'm turning over a new leaf. I want my car to look like it did when it first got to NYC. Here is what I've been upto... tell me where I went wrong...
I washed my car using Meguiars Nxt Generation
Clay's the entire car. Took HOURS. A lot of surface containments.
Using a G110 DA buffer with a Soft Buff 2.0 Polishing Pad I applied some Ultimate Compound. I noticed all of my bad water spots remained, even after 3 or 4 applications using a high speed setting a bit of pressure on the buffer.
I was getting frustrated with the Ultimate Compound so I went to the part store and picked up the most agressive stuff they had. "Mirror Glaze Fine Cut Cleaner #M0216" It's a "mildly agressive", and is described at only being able to remove fresh water spots. Ugh. I went ahead and applied the Mirror Glaze with a new Soft Buff 2.0 Polishing pad . I didn't have a cutting pad....
Low and behold the spots remained... they looked no different after a lot of hard work, even with the buffer.
I cut my losses and decided to keep going with my project with the products I had on hand. I went over the entire car using the Mirror Glaze and didn't continue with the Ultimate Compound.
After the Ultimate Compound I used Swirl X to buff it to a better shine. I used the DA Buffer with a Soft Buff 2.0 Polishing Pad.
After that I used Deep Crystal System Polish with the DA Bufer and a Finishing pad to help darken my black paint.
Then I used Nxt Generation Tech wax with the Buffer and a Finishing pad.
What Can I do to get these darn spots gone? Can a DA buffer buff these out, or do I need a standard rotory? Yikes!
