What have you guys found thats the easiest way to remove swirl marks from ceramic clear coats?
Ceramic Clear Coats
Tags: None
Re: Ceramic Clear Coats
The process is the same as removing swirls from a traditional clear coat but in some cases you might need to do more passes or use a more agressive product.
It is best to do a test spot to determine how hard or soft the paint is first. Some ceramic clear coats are suprisingly soft while others are really hard.
What type of car are you working on?
RyanAttack life, it's going to kill you anyway.
A 2008 F430 Scuderia, and a 2006 612 Scagletti... they took forever to do
also a 2008 599 GTB fiorano, they all came out perfect but took way to long...
Well, if the ceramic clear coat is soft enough then M105 might not be neccesary, maybe just M205 would remove the swirl marks?
use the least aggressive product to get the job done, just dont go straight to M105 Ultra Cut Compound. Try a cleaner/polish first such as M80 Speed Glaze, SwirlX, M205 etc. A compound is a lot stronger than a cleaner/polish and theres no point in removing more clearcoat than necessary to remove the swirls.
hope this helps.Nick
