Saw this on ADS. Has anyone used it? Is it effective? Do you like it?
Hi-Tech Eraser Sponge?
Re: Hi-Tech Eraser Sponge?
I have never used one..
But I think it is basically the Mr. Clean Magic Eraser.
Which I have found works great inside the home, there is/was a Mr. Clean Magic Eraser for Wheels, which worked fine, but it tended to shred up, so I did not stick with it.Joel
If you ever buy electronics and it comes in the dark gray foam-like packaging
use it instead of Mr. Clean erasers. The gray foam has the same consistency as the Mr. Clean pads, works just as well with water or APC. The only reason the MC pads work is that they are more abrasive than cloth and the gray foam works the same.
