Re: C5 Vette - 1st DA Use
There is no normal, every paint system buffs differently, some paints buff really great and some don't, what works great on one paint might not always work great on a different paint, that's why it's important to test like you're doing.
If the M105 is leaving fine swirls then go ahead and try the M205 with a finishing pad next. Do a Test Spot so you can compare the M205 results with the M105 results. Usually the hood is a good place to do your test so you can look down on the finish when inspecting.
M205 is a light cleaner/polish and M07 is a non-abrasive pure polish, they are very different product but actually product very similar results. If the finish looks great after the M205 then might as well move on to the wax step. Meguiar's always states polishing with a pure polish is an optional step so you can if you want but because M205 takes your paint to maximum clarity, you can skip the #7 step and go to the waxing step.
If you have paint anywhere on the car that is thin enough that if you were to rub it by hand and go through, then yes a DA Polisher could also burn through this same area. If you're paint is still in good condition then it's usually the least of your worries.
Originally posted by Demon_C5
View Post
View Post
View Post
