Re: C5 Vette - 1st DA Use
At this time we don't offer anything smaller than our 6.5" buffing pads.
As for the hard to work areas, just tackle these by hand with either UC or M105 and a foam applicator pad.
Give the oval shaped applicator pad a try to see if it works for you, I found it too large to be practical for working out defects in small areas, for this I just use the normal foam applicator pads Meguiar's sells. The trick to working swirls and scratches out of hard to work areas is time. That is get comfortable by sitting down at a level so you're looking across from the area you're working and rub the paint out methodically and thoroughly.
Any of these should give you good cleaning/abrading power for working out swirls and scratches by hand,
M105
Ultimate Compound
ScratchX 2.0
Heck, I rubbed out each one of the louvers on this Mosler by hand using ScratchX 1.0 (I wish we had SMAT products out back then)
LSP applied (NXT in this case after machine cleaning and polishing)
LSP removed
Originally posted by Demon_C5
View Post
M105
Ultimate Compound
ScratchX 2.0
LSP removed
