Orange Peel
Results 1 to 9 of 9
Thread: Orange Peel
    Apr 2009
    USA
    Orange Peel
    Hi, will 3000 grit wet sanding get rid of orange peel?
    Its my first time doing it so I don't want to get too aggressive. Is 3000 grit dangerous for a beginner at all?
    how would i sand concave surfaces? just press a foam pad down into it?
    Also, is 3000 grit safe to use near or on the edges? I got a cheap spot bumper repair with lots of orange peel. they aren't willing to fix it because the price of the bumper repair isnt enough to pay for a new coat of paint in case they fail. they taped it off at the edges. Is it safe to try smoothing that out or is it better to leave it alone.
    will hand compounding with 3M rubbing compound get rid of sanding scratches?
    41
    19,269
    239
    Re: Orange Peel
    What are you working on?
    Apr 2009
    USA
    Re: Orange Peel
    a bumper spot repair with orange peel
    Nov 2004
    SoCal
    2,313
    43
    Cool Re: Orange Peel
    Sorry to be negative, but....
    "...will 3000 grit wet sanding get rid of orange peel?"
    Not really. #3000 is meant for removing sanding scratch caused by coarser abrasives. To remove OP from a topcoat you'd typically use something between #1000 and #1500.
    "Its my first time doing it so I don't want to get too aggressive. Is 3000 grit dangerous for a beginner at all?"
    Any and all sanding is dangerous for a beginner. One should practice a lot before working on anything you care about.
    "how would i sand concave surfaces? just press a foam pad down into it?"
    Yes, it's typically done with flexible backing pads.
    "Also, is 3000 grit safe to use near or on the edges?"
    See second answer above, only a lot worse.
    "I got a cheap spot bumper repair with lots of orange peel. they aren't willing to fix it because the price of the bumper repair isnt enough to pay for a new coat of paint in case they fail. they taped it off at the edges. Is it safe to try smoothing that out or is it better to leave it alone."
    Impossible to say. But if the guys who did it think it's too thin to withstand sanding, I'd believe them.
    "will hand compounding with 3M rubbing compound get rid of sanding scratches?"
    Maybe, eventually, in theory. Practically? Probably not.
    If you decide to try be prepared to start over with a full sand and repaint from scratch.
    pc.
    aka andrewc_11890 Andrew C.'s Avatar
    Jun 2008
    San Clemente, California
    1,981
    45
    Re: Orange Peel
    If they think there is a possibility of the paint not being thick enough then I definitely would not try it unless you are willing to pay to get your bumper repainted if you mess up
    Remove swirls my friends.
    Self-Banned
    Nov 2006
    1,396
    0
    Re: Orange Peel
    Quote Originally Posted by the other pc View Post
    pc.
    Were've you been Paul?
    DETAIL ARTIST roger 668's Avatar
    Jun 2008
    chambersburg pa
    66
    14
    Re: Orange Peel
    Most times you can smooth out the peel with a rotary and a compound,always begin with your least aggressive pad and compound!!
    roger
    'Pearly Gates' Eddie6th's Avatar
    May 2009
    Italy
    3,169
    92
    Re: Orange Peel
    Anyone here find most new cars today start off with orange peel ? New paint mixtures ?
    Self-Banned
    Nov 2006
    1,396
    0
    Re: Orange Peel
    all paint has some degree of orange peal
  1. Orange Peel Effect?
    By mb911 in forum Detailing 101
    Last Post: Sep 20th, 2008, 01:07 PM
  2. What makes orange peel occur? Can You Stop it?
    By Carfire in forum Detailing 101
    Last Post: Sep 19th, 2008, 03:59 PM
  3. How can you get rid of orange peel?
    By mckeand13 in forum Detailing 101
    Last Post: Apr 4th, 2007, 07:03 PM
  4. Severe orange peel
    By NascarFool in forum Sanding Automotive Paint - Hand/Machine
    Last Post: Nov 29th, 2005, 08:18 AM
  5. Orange Peel
    By Jeff Smith in forum Detailing 101
    Last Post: Sep 8th, 2005, 10:29 AM
