Re: Fixing a million rock chips
I've got an update from tonight.
I went to the dealer and picked up some touch up paint and clear coat.
Since I have a ton of chips I decided to experiment with a few. First I read to clean the area with some rubing alcohol so I put some on a MF cloth and rubbed down a chip. As I did this I noticed the thin touch up paint I had was coming off. Since I had the dealer touch up paint, I decided to just keep it up for the chips on the left side of my hood.
So using a MF cloth and rubbing alcohol I managed to rub off the excess thinned touch up paint and on a few chips it appeared to leave the paint inside the chip. Unfortunately on the other few it removed all the paint. No worries I had the dealer touch up paint.
Well anyway I then moved on the the right side, where I hadn't touched any chips that last night I applied the body shop provided thinned out touch up paint. I decided to grab the clear coat and apply it to some of the chips, even though they weren't really level yet. After I did this though I something became very apparent to me:
The thin paint from the repair shop was a perfect match!! It simply lacked a clear coat so it looked dull! After applying the cleat coat it looks great.
The dealer paint is off color, but it is thicker. So here's my new question and I believe final solution:
How do I thicken the body sho provided touch up paint? It's like water, I could do layer after layer on each chip but it spreads around the entire area, I can't isolate it to within the chip.
Should I leave it as it is, apply several layers (if so how many?) to each chip, then blob the clear coat on?
