Extractor Soap ? chemicals ?
Results 1 to 9 of 9
Thread: Extractor Soap ? chemicals ?
    Registered Member karma's Avatar
    35
    14
    Lightbulb Extractor Soap ? chemicals ?
    For those of you using a carpet extractor what soap do you use in your machine also does everyone use defoamer? Ive ordered a mytee lite II recently and was waundering which chemicals to put in it. one last thing should I pre spay or just use like a vacuume?
    Thanks I trust yall experts out ther will have some good answers thanks!
    Jason
    Professional Detailer Jimmy Buffit's Avatar
    Indianapolis, IN (Carmel)
    290
    17
    I spray an all purpose cleaner
    All Purpose Cleaner
    directly on the carpet or upholstery, agitate where needed, inject the 210 degree water with 100psi (This is where the action occurs). Then I use the extraction mode to remove 95% of the water and debris.
    Putting a detergent IN the extactor leads to scum buildup, and just isn't necesary.
    I do add an enzymatic odor terminator (neutral scent), which is VERY effective.
    Be sure to run a gallon of white vinegar thru the extractor either weekly, or after every ten fresh fills.
    Good Luck!
    www.jimmybuffit.com
    Registered Member Teak's Avatar
    691
    21
    Jim,
    Thanks for the good info.
    Do you think an odor terminator would work in a Bissel Little Green Machine?
    Eric
    290
    17
    I've not used the LGM, but I would think that it would be effective...
    Can't hurt.
    Jim
    www.jimmybuffit.com
    Jun 2004
    62
    14
    Eric i have used an odor terminator in my little green and it works great
    691
    21
    Thanks guys.
    Eric
    Self-Banned
    May 2004
    79
    0
    Ive never heard of running the vinegar through whats it suppose to do remove lime and scale becuase if it does i should run a full tank because everytime i go to use my sprayer the tip is clogged and i have to take it apart and clean it.
    Okanagan Valley, BC
    4,544
    391
    Hey,
    Vinegar, contains Acetic Acid ( CH3CO2H) an organic carboxylic acid that will help eliminate scale, mild mineral deposits etc. from plugging up your extractor.
    Tim
    I am the paint whisperer. Superior Shine's Avatar
    Feb 2004
    Covina / Los Angeles
    4,732
    205
    Good Luck! [/B]
    We use DI water in our machines and don't have the build up problem. Otherwise we clean interiors exactly as jim.
  1. Getting $1300, should I get an extractor?
    By kpagel in forum Detailing for dollars
    Last Post: Jun 1st, 2006, 10:14 AM
  2. Pro chemicals vs. DIY chemicals
    By CELL in forum Detailing for dollars
    Last Post: Feb 13th, 2006, 10:13 AM
  3. what happpened to the extractor
    By sneek in forum Interior Care
    Last Post: Nov 29th, 2005, 03:25 AM
  4. Replies: 1
    Last Post: Nov 30th, 2004, 04:47 PM
