How to do a Test Spot
Results 1 to 2 of 2
Thread: How to do a Test Spot
    59
    24,767
    519
    TEST SPOT
    Before going over the entire car, see if you can make just one small section look good, that is apply the product you're planning on using over the entire car to just one small section about a foot squared or so. Work it in and then wipe it off, then apply the polish, work it in but not as much as the compound because now you're not trying to remove paint, just spread the product out, then immediately wipe it off, then apply the wax and let it fully dry and then wipe it off.
    Now inspect our results. Make sure you can make one small section look GREAT before going over then entire car. If you can't make one small section look GREAT you won't be able to make the entire car look GREAT.
    Make sense?
    It should look like this,
    And if you're having any problems, the post back here after the test section and we'll help you tweak your technique to insure you get it right.
    Jul 2010
    NY
    Re: How to do a Test Spot
    sounds good to me
  1. The Squeak Test - How to test for the presence of wax
    Last Post: Apr 24th, 2013, 12:53 AM
  2. Test thread
    Last Post: Oct 19th, 2008, 02:15 PM
  3. Replies: 24
    Last Post: Sep 21st, 2008, 02:22 PM
  4. How to test for a clear coat or single stage paint system
    Last Post: Aug 27th, 2008, 06:53 AM
Tags for this Thread
